Bogging engine when at part throttle
Jaydium
Post by Jaydium » July 02, 2006
Engine : B16A
ECU : PR3
Car : 1991 CRX Si
when from a light, ill let off the clutch and give it some gas, once the clutch is fully released, ill be at part throttle, and the motor seems to bog and then all of a sudden "kick" in and go...if i'm on the freeway, say at 70 in 5th gear, it will bog until i give it more than 1/4 throttle.. what is the problem here? ive been told to block off the o2 sensors but that only seems like the car would then be running rich. ive also been told that its just a common problem when converting obd1 into obo0, and ive also been told that it could be a "drying fuel pump"....the car has new plugs/wires/cap/rotor/fuel filter/fuel pressure regulator.
what is the problem? i dont believe its a timing issue, and the "drying fuel pump" doesn't make much sense to me, i was always under the impression that a fuel pump either works or it doesnt... so someone help me out here...thanks
JDM Whore
Jaydium
ttt
Post by Sean @ NDF » July 02, 2006
that happens to me sometimes also, when i floor it very quickly. curious to know an answer
CivicSpoon
Post by CivicSpoon » July 02, 2006
You did the dpfi to mpfi conversion? What are your rpms at idle and at 70mph (roughly)? Throwing any codes?
Jaydium
Post by Jaydium » July 03, 2006
NOUYA USA did the swap (in VA)...not throwing any codes
Jaydium
Post by Jaydium » July 13, 2006
ttt
Post by hondalowlow » November 21, 2006
bad tps sensor
Post by Sean @ NDF » November 22, 2006
bump because I'm curious if this was fixed. Like I said, this happens in my daily driver. Im beginning to become convinced it has something to do with my fuel system, most likely the fuel filter BUT we could have totally different problems.
Post by Secret Squirrel » November 23, 2006
MAP sensor. or a vaccum leak
Post by hondalowlow » November 23, 2006
change your tps or clean out your map sensor it gets carbend up.
