opnions needed ....
opnions needed ....
Post by hondalowlow » August 26, 2006
ok so i build my engine over the winter and it runs fine for 4 months , then all the sudden me and fetterman were out last friday and we were putting it under a good load running people on the highway and in town for about 1/2 hour. the temp was a litle above normal then we parked the car at the bank then the temp shot up to hot , like full fucking pegged so i shut off the car and let it cool, so once cooled i start it back up then its fine, i drive back to homer city and its a little above normel agine but no problems. runs good through saturday, sunday monring runs great ythen i go to take it to the e-burgh flash light drags, then it runs good until i hit yellowcreek dip then the temp gauge is in the middle,so i coast for a bit then i pull 5psi up over nolo hill "its a pretty long hill:" i get to the top its in the 3/4 range then i coast down over the backside then back to normal temp. then i get to
e-burgh im by votech then all the sudden like a slap in the face wham back pegged off hot agin so i shut down and let cool once agfin normal temp. drive to my g/f's house in e-burgh let cool added water to make up for coolant lost on the way. missed the flashlight drags, and on the way home IT RAN FINE AND DIDNT EVEN HEAT UP ONCE. THE TEMP WAS BELOW COLD MARK.
no thermostat, and singe core rad.
this week i added 180* thermostat and a SI dual core rad and new fan "constant running"
last ngiht sitting in construction in indiana on my way to wal-slut , it goes from ok to middle then to 3/4 hot... i drive it cools down to normal... i get to wal-mart it goes to 3/4 when i park..
its like i need more airflow goign through it or someting..cause when i drove it it cooled off real quick but when it sits there it heats up..not the temp sensor because of coolant lines are hard as a rock due to pressure from hot coolant.
im still thinking head gasket, but everyone elese says no."by the way cometic HG, once agin everyne saying theres no way that they blow under 10psi.."im thinking defect.
today im going to
re-torque my head studs "incase of strectching"
pull thermostat out
add more water 70% water 30% coolant/royal purple purple ice
gimme your opnions..please reply.
Dont Blink
60% ricer
Post by Dont Blink » August 26, 2006
i wouldnt completly remove the thermostat. go get a stant 160 or 170 dergree thermostat. chain part store should have them. coolant has no oil spots floating in it? oil has no water in it? car blowing white smoke out the exahust?
idreamidrive
Post by idreamidrive » August 26, 2006
did you ever think about your waterpump being bad? also if you are running lite weight pulleys it is not as efficient as the regular pulleys at spinning the water pump
Signature
Post by Secret Squirrel » August 26, 2006
If it just started doing this then obviously something has gone bad...thermo, water pump, HG are all very plausable problems.
Post by hondalowlow » August 31, 2006
the coolant system is pressuring up under boost. 15 psi
because when i let cool and sit over night i will take the rad cap off in the morning and psssst.. pressure in the rad. "car hasnt ran in 10 hours" so im guessing that the cometic head gasket could of got a hairline scratch in it douring install and the pressure has finally pushed through.
no oil in anti freeze. just small whte bubbles " its like foaming up"
no anti in oil
i just ordered a set of y8 ARP head studs and a new cometic head gasket.
but when i remove the ehad i will throughly inspect it for hairline cracks and same with the block. but everyone is saying HG in the most part.
if its the engine thats messed up good bye D16 hello B18
:bang:
Post by BRYCE » August 31, 2006
SELL IT!!!
nah jk i just didnt want to read your post
nice s-14 bryce i like it alot.
Post by hondalowlow » September 20, 2006
it was the cometic that blew under 15psi. #4 cyl let loose on the intake side. i rebuilt my y8 this past weekend with vitara pistons eagle rods,arp studs and a new cometic and i put on a ex tranny. i will have the car running and on the road tommrow.
