need some help...
nizzan1984
need some help...
Post by nizzan1984 » June 08, 2007
while driving around today, i noticed a problem w/ the car... if you turn the heat or ac on, it shuts out kinda like it has a short. i took the center console out awhile ago so idk if i accidently pulled a wire out, or sumthin like that. any help would be greatly appreciated!!!:-D
"God invented turbo lag to give the domestic guys a false sense of security."
jdmcivic98 wrote:Jewish Domestic Market
Highway-Star
Post by Highway-Star » June 08, 2007
you mighta knocked a ground wire. Could be loose, might wanna check those
Post by Secret Squirrel » June 08, 2007
better discription. Does it blow for a split second? not blow at all? blow then stop then blow again?
nizzan1984
Seductive Squirrel wrote:better discription. Does it blow for a split second? not blow at all? blow then stop then blow again?
yea, it blows for a few seconds... shuts off, and starts blowin again. my tach also kinda stops working and its beenhappening alot so im thinking a wire too, just gotta find which one...:o
Post by .saint » June 08, 2007
ahhh good luck finding the short. haha.
Highway-Star
probably a bad ground or a bad wire.
when you pull everything out, start the heat or a/c, and wiggle some of the wires. If it IS in fact a wire, or a connection to a wire, you can normally find it with just wiggling. Just my opinion on what to do!
ill vouch for the wiggle trick, thats how i fixed my navigation.
Highway-Star
thats how i fixed my cluster :P
vtjdmsir
Post by vtjdmsir » June 09, 2007
there might be a wire pinched some where
James Goodyear
thejdm.com / 802 Squad
nizzan1984
Post by nizzan1984 » June 09, 2007
thanks for the help guys... so are the wires behind where the ac is and all that stuff?
