97ek4 auto to 5-spd swap
Post by hondalowlow » December 12, 2004
i got a hydro D sires tranny.. hahah
i need shift linkages
shifter
hydro lines and clutch resvior
3 pedal assembly for clutch pedal
DO I NEED A 5 SPD ECU?????????????????????
there are 2 wires coming out of the auto tranny
thry are for the reverse lights...
please fill me in on this swap i got the extra $ from x-mas cards and i wann get a 5-spd in ASAP! im sick of the auto tranny
Post by hondalowlow » December 13, 2004
would someone please reply to this post and let me know what i all need... thnaks
just teg'n it
70% ricer
Post by just teg'n it » December 13, 2004
5spd ecu would be good yeah.. i know for a B series you need it.. from auto to manual the auto ecu would be going through more data i would assume for shift points etc.. that's all i can help you with.
sfc
15% ricer
Post by sfc » December 13, 2004
someone on here did it with their integra... I believe red2teg or whatever his nick is, you should try pm'n him, or posting in the general forum so some other people who might not read this one can maybe help you out :)
fltblkteg
80% ricer
Post by fltblkteg » December 13, 2004
you shouldn't need a different ecu you'll just eliminate some wires
Post by munster » December 13, 2004
I think you might need a 5spd ecu. I'll check it out.
PM redg2integra
You do need the ecu. There's a bunch of sensors in the auto tranny. You'll throw a cel.
Here's the parts list(taken from honda-tech):
5 speed tranmission
clutch (pressure plate, disc)
shift linkage
manual ECU
manual starter
flywheel
clutch master cylinder
slave cylinder
hydraulic lines
pedal assembly
tach (if you want one)
shifter
shift knob
shift boot
miscallaneous nuts and bolts!!
Check these links too.
http://honda-tech.com/zerothread?id=550221
http://honda-tech.com/zerothread?id=946332
http://honda-tech.com/zerothread?id=930084
http://honda-tech.com/zerothread?id=829202
fltblkteg
80% ricer
but technically you don't need the ecu for it to run come on munster it's jude he never does it the right way just as long as it runs
haha. CELs are cool.
Post by hondalowlow » December 15, 2004
common don... my ef is sold and blew up... my ek is gonna be done right and its has been for everything i did to it.. i got the $ now and i dont do shit half ass no more....
the 91 was a mess i agree.. but the 97 is gonna be nice trust me...
but thanks for the help guys... don i need shift linkages... i got a clutch assy and lines tranny , mounts, brake pedal , i need ecu and shift linkages... i got flywheel from a ef and a clutch from a ef.. its d-sires so they should work... i hope... :( .
