97ek4 auto to 5-spd swap
i got a hydro D sires tranny.. hahah
i need shift linkages
shifter
hydro lines and clutch resvior
3 pedal assembly for clutch pedal
DO I NEED A 5 SPD ECU?????????????????????
there are 2 wires coming out of the auto tranny
thry are for the reverse lights...
please fill me in on this swap i got the extra $ from x-mas cards and i wann get a 5-spd in ASAP! im sick of the auto tranny
shifter
just teg'n it
- 70% ricer
You do need the ecu. There's a bunch of sensors in the auto tranny. You'll throw a cel.
Here's the parts list(taken from honda-tech):
Check these links too.
http://honda-tech.com/zerothread?id=550221
http://honda-tech.com/zerothread?id=946332
http://honda-tech.com/zerothread?id=930084
http://honda-tech.com/zerothread?id=829202
5 speed tranmission
clutch (pressure plate, disc)
shift linkage
manual ECU
manual starter
flywheel
clutch master cylinder
slave cylinder
hydraulic lines
pedal assembly
tach (if you want one)
shifter
shift knob
shift boot
miscallaneous nuts and bolts!!
common don... my ef is sold and blew up... my ek is gonna be done right and its has been for everything i did to it.. i got the $ now and i dont do shit half ass no more....
the 91 was a mess i agree.. but the 97 is gonna be nice trust me...
but thanks for the help guys... don i need shift linkages... i got a clutch assy and lines tranny , mounts, brake pedal , i need ecu and shift linkages... i got flywheel from a ef and a clutch from a ef.. its d-sires so they should work... i hope...
