thermostat help
Post by Nikku » October 31, 2005
Secret squirrel wrote:yea...but in theory im correct?
cuz all the engine is is an air pump. so if more of the chemical reaciton is turned into work and less into heat there would be more power, so runing hotter temps means less heat loss, which means more chemcical energy bing turned into usable work
logical however incorrect, if your engine is running hotter then you run the risk of being closer to detonation, etc
Post by Secret Squirrel » October 31, 2005
that would be the case if iwas runing extemely hotter, but im talkin 10-20 degrees
Secret squirrel wrote:that would be the case if iwas runing extemely hotter, but im talkin 10-20 degrees
10-20 degrees can make a world of difference
yes when it comes to 220+ degrees
Post by Sean @ NDF » November 01, 2005
let me see if my two cents helps at all:
most engines now are designed to run at a certain coolant temperature in order to make the fuel burn correctly and at the right temperatue for the best power and unfortunatly to keep your cars emissions at bay - probably for gas mileage issues too. If you switch thermostats it will change this set temperature and MIGHT cause small problems i.e. worse gas mileage, overheating, etc.
I say unless hes driving his car really hard and/or racing it every week he keep with a stock setting thermostat...
again, just my dime and a half
*edit - although I do see where your coming from SS, I don't think in the case of the fluid temperature it will help performance. That theory is more towards exhaust gases and what not
Post by Nikku » November 01, 2005
banzai wrote:let me see if my two cents helps at all:
true, but one thing that we all must remember is that cars in the US are not designed for any specific region, the car mfg's just kinda say "we think this will work best everywhere", if you are in a colder climate you may want a different temp thermostat, and the same holds true for a warmer climate
sikblugsx
75% ricer
Post by sikblugsx » November 01, 2005
why not just leave it alone , unless it's stuck shut your just wasting time
sikblugsx wrote:why not just leave it alone , unless it's stuck shut your just wasting time
not true
tommybanzai
25% ricer
Post by tommybanzai » November 01, 2005
What kind of car is this?
I think he should just get a stock one...
