whats the best
you will spend almost the same for a sohc vtec as a LS......
d-series all motor stinks if you plan going boost then sohc will be fine but since you are on a budget im guessing turbo is out....so save and go with a LS just my opinion though.
98BomexCiv
- 75% ricer
I totally agree with knauff d-series all motor suck. Save your money get a ls swap and you wont be unsatisfied trust me....vtecdood wrote:you will spend almost the same for a sohc vtec as a LS......
Well the problem is if you go vtec head and everything else you will need to do a bunch of upgrades in order to go sohc vtec so what you will spend on getting vtec in a obd0 car you can have an LS and its a direct bolt in. If you are getting rid of it then leave it alone whats the point in modding if you are not going to build from the swap you put in sounds like you are going to waste alot of time and money.
- boostjunkie95
well the thing is im not sure if i am infact going to keep it or not. i might keep it, or i might get something different. my engine is getting old and weak and dosnt have any power at all. i just want something that is fun, and that i have the ability to mod if i want.vtecdood wrote:Well the problem is if you go vtec head and everything else you will need to do a bunch of upgrades in order to go sohc vtec so what you will spend on getting vtec in a obd0 car you can have an LS and its a direct bolt in. If you are getting rid of it then leave it alone whats the point in modding if you are not going to build from the swap you put in sounds like you are going to waste alot of time and money.
i dont know, if you guys have any better suggestions, im all ears.
problem_si
- 95% ricer
DOHC ZC hands down.
Low end power, dual cam, direct drop in motor for around $400-600. No wiring issues, can stay OBDzero, can use stock ef tranny. You can even use stock ecu, a zc ecu, or a 89 Teg unit that can be found at a junkyard for like $20.
If your dying for the extra 20 hp that a b16 gives you, just get a set of cams for like $300
that sounds like a good plan. i was thinking about this tonight.problem_si wrote:DOHC ZC hands down.![]()
i was thinking about ditching an engine swap, and just getting oter less pricey stuff like exhaust, intake, and suspension goodies. saving the rest of the money for a car, hopefully an EP next summer.
or i could say fuck that, get an engine swap and build the shit out of it.
i think i like the first choice more...
problem_si
- 95% ricer
