HUGE SALE! A MUST SEE!
approved & sponsored vendors & advertisers classifieds.
trupowermotorsports
Post by trupowermotorsports » May 15, 2007
Our dealers have a huge overstock , which is good because that means cheap products! Heres a huge list of everything that must go:
PLX DEVICES:
iMFD Display Modules
Image DM-100 52mm OLED Universal Gauge w/ Control Box and Remote
The iMFD DM-100 is a 52mm (2 1/16") universal gauge designed specifically to display a wide variety of automotive information far superior to that of a standard automotive gauge. The DM-100 can display up to 4 different sensors simultaneously and can be connected in a daisy-chain with up to 32 sensor modules and 32 other display modules.
Features Include:
# real time plotting
# customizable gauge styles, backgrounds, colors
# digital display
# organic LED
# set peak and hold points
# can display data from 4 modules at once
# simple to install
# PC interface software included
# comes with remote control
$210 Plus Shipping
Image 52mm Wideband Air/Fuel Ratio LED Gauge in Black Face
The PLX DM-5 AFR is a standard size 2 1/16" (52mm) LED automotive display designed to display the values measured from the SM-AFR. Measuring only 0.7" (18mm) thick, it can virtually be mounted anywhere. The DM-5 is designed to fit into most aftermarket 2 1/16" (52mm) cups, and mounts for seamless integration into your vehicle. This is an ideal accessory for your SM-AFR module. Up to 32 can be daisy chained together in the iMFD system.
$76 Plus shipping
Image 52mm Wideband Air/Fuel Ratio LED Gauge in White Face
$76 Plus Shipping
iMFD Sensor Modules:
Image Air/Fuel Ratio Sensor Module w/sensor
SM-AFR accurately measures the precise air/fuel ratio (AFR) of any internal combustion engine. Up to 32 SM-AFR modules can be daisy chained together in the iMFD system. SM-AFR can also be used as a stand alone unit capable of interfacing with 3rd party hardware. All Sensor Modules are housed in high quality extruded aluminum designed to operate even in the most extreme conditions. In addition, all SM modules offer outstanding digital accuracy, response and resolution which far exceeds that of a standard gauge.
$161.50 plus shipping
Air/ Fuel Ratio Sensor Module w/o Sensor
$130 Plus shipping
Wideband air/fuel ratio products:
Image R-500 Wideband Computer Kit w/EGT Probe
Designed for the advanced tuner, the R-500 combines 3 essential parameters (Air/Fuel, EGT, Knock) of internal combustion engine tuning into one! Whether you're on the dyno, track, autocross, street or drag strip, the R-500 can be fully customized to suite your individual application. With intuitive user menus packed with features, merged with powerful PC software, there is virtually nothing that the R-500 can't do.
Features Include:
# Measures Air/Fuel Ratio, EGT, Knock, and Boost
# Integrated 6 Inputs for data logging (2 Speed, 4 Analog)
# 90 minutes of onboard memory for recording and PC download
# Integrated "Real-time dyno." Measure your HP, TQ without expensive trips to the dyno.
# 4 analog outputs (User configurable) for 3rd party interface
# Replace your stock narrowband sensor.
# Fully customizable LED warning light or shift light
# High speed USB 2.0 interface
# Powerful 32 bit integrated processor, RAM, and FLASH technologies
# 100% backwards compatible with M-Series controllers
# Compact dash mountable design (4.75 x 2.25 x 1 inch)
# Powerful PC analysis software included
$500 Plus Shipping
Image R-500 Wideband Computer Basic Kit
Features Include:
$460 Plus Shipping
Image R-300 Wideband Computer Basic Kit
The R-300 is a compact, dash mountable, easy to use wideband air/fuel controller with powerful data logging capabilities. Wideband air/fuel ratio can be monitored in numeric, gauge or graphical form. Data logger inputs can be fully customized to display virtually ANY type of data. It's like combining 6 gauges into one! The R-300 can store up to 90 minutes of logged data and 99 individual sessions for later PC download and analysis with PLX Logger PC software.
# Measures Wideband Air/Fuel Ratio
# Integrated 6 Inputs for data logging (2 Speed, 3 Analog, 1 AFR)
# Analog outputs for 3rd party interface
# Sensor soft start circuitry, prolongs o2 sensor life
$365 Plus Shipping
Image Wideband Oxygen Sensor Controller with Display
The M-Series Wideband Oxygen Sensor Controllers are extremely simple to use and to setup. They do not require complicated sensor calibration procedures nor do they require any confusing software setup. Simply, connect the power wires to a 12V source, snap the sensor wire harness with the oxygen sensor and you're ready to start measuring your automobile's air/fuel ratio within minutes! PLX Devices widebands are guaranteed accurate to 0.1AFR with race proven technology which yields extremely fast reaction times.
# Works with standalone engine management systems. Accurate Air/Fuel Ratio < 0.1, Fast Reaction
# Advanced Sensor Self Calibration Circuitry. No manual calibration required.
# Wideband LINEAR Analog Output (0-5V)
# Narrowband Analog Output (0-1V)
# Replace your stock Narrowband sensor.
# 32 MHz Advanced DSP Technology
# Built in Resettable Fuse (No external fuse needed)
# Sensor soft start circuitry, prolongs o2 sensor life.
# Compact and Professional Design
# "Plug and Play" Installation
# ISO 9002 Certified Assembly
$275 Plus Shipping
Blackline GPS:
Image GPS Snitch
Changing the way you protect your vehicle, the GPS Snitch is a purpose-built wireless vehicle security and tracking solution. Small enough to be hidden almost anywhere, GPS Snitch gives you the power to locate your vehicle on demand using the internet or web-enabled cellular phone.
To learn more about the Blackline GPS "Snitch", please visit GPS Snitch.com.
Features include:
# Real-Time Tracking
# On-Line Interface
# Mobile Interface
# Nationwide Coverage
# Alarm Notifications
# Alert Types Motion Alert and Security Perimeter Alert
# Notification Methods- Text message to mobile phone and e-mail
# Remote Arm / Disarm From Mobile Phone
# Speed and Direction Reading
# Location Request Response Time- Typical 30 to 45 Seconds
# Location Request Response Time- Optimal 10 to 15 seconds
# GPS Tracking Sensitivity -155 dBm
# Internal Motion Sensor
# Rechargeable Battery Inside
# Recharging Time 4 to 6 hours
# Standby Use Time- 7 days
# Typical Use Time- 4 to 5 days
# Optional Hard-Wiring Kit
# Connector DC jack
Note- There is a one time activation fee ($29.99) as well as a monthly service plan (as low as 14.99 per month) with this product. This is not included in the cost of the price.
The Snitch requires GSM coverage. Please check with your cellular provider.
$300 Plus Shipping
trupowermotorsports
Advanced Automotive Concepts:
HID Kits:
Image H1-$250
H3-$250
H4-$250
H7-$250
H8-$250
H9-$250
H10-$285
H11-$250
H13-$285
9004-$285
9005-$250
9006-$250
9007-$285
D2R-$285
D2S-$250
Prices Dont Include Shipping
Headlights:
04-06 Acura TSX Kit Image ORACLE Halos are the best Demon Eye kits produced for any vehicle. Do not mistake this product for some “do it yourself” knock off Demon Eye Kit. This is a high quality product produced by the new leaders of the industry, Advanced Automotive Concepts (AAC)! This kit uses Cold Cathode technology, which can be seen vividly, even in direct sunlight! It is better than LED or fiber optic kits. The rings are rated at 50,000 hours of continuous use, twice the lifespan of competition! The fitment for the vehicle is up to OEM standards.
Kits are made for each type of vehicle and are not universal in nature like other competitors where fitment problems occur.
Made of glass, and not plastic or other materials like competitors.
These kits are made here in the United States.
Kit Includes:
(2) 6000K Hi Beam Rings
(2) 6000K Lo Beam Rings
(2) Oracle Halo Ballasts
Wiring, Connectors, and Hardware
Written Installation Instructions
Installation DVD (not all models)
$175 Plus Shipping
Autopage Security Systems:
Alarms & Remote Starts:
Image 6 Channel Security and Remote Car Starter System with 2-Way FM/FM OLED* Transceiver
* Organic Light Emitting Diode display with vivid color animated motion graphics
Product Features Include:
1. USB 2.0 port for battery charger and future downloads
2. Jog-shuttle for personalization and programming
3. Backlit buttons for nighttime usage
4. Personalized 4 car operational
5. Elegant platinum color finish with U.V. coating
6. New Manchester Code encoder with 900 MHz transceiver for exceptional range and communication
7. New 2-Way, window mount Super Extended Range (1 Mile) transceiver antenna module
NOTABLE FEATURES:
1. Standard 1-way AM 900 MHz remote transmitter with sliding cover for use as back-up or secondary remote. Sliding cover to prevent accidental misuse.
2. Battery charger with wall plug and USB 2.0 port included
3. New plug-in type Super Bright BLUE LED
4. New on-board MICRO RELAYS for reduced main unit size without loss of performance (parking lights/starter/ACC/ignition 1&2)
5. Programmable Single/Double Pulse Unlock w/ 7 new timing adjustments
6. New 2007 GM non-starter wire compatibility
7. New Dedicated Second Start Wire
8. New Dedicated Ground out when running wire
9. SIS-11 super intelligent dual stage shock sensor, temperature sensor and paging knock sensor included
10. Three auxiliary channel outputs programmable to momentary, pulsed, latched or timer control output.
11. Remote car starter with 5 on-board relays
12. Tachometer learning, voltage or timer start modes
13. Selectable one or two push "safety" start
14. Gasoline or diesel compatible with 10, 15 , 20 OR 30 second "wait-to-start"
15. Programmable factory keyless door locking before and after start
OTHER IMPORTANT FEATURES:
1. "Turbo-Timer" Feature
2.Temporary Stop Feature
3.Selectable Chirp Confirmation
4. Window "Comfort Feature" with OEM systems having key / remote control power roll-up
5.Dome Light illuminated entry
6.Code Learning / Anti-Scan, Anti-Code Grabbing
7.Much, Much More!!!
$350 Plus Shipping, Retail at $800!
Image 6 Channel Security System with 2-Way FM/FM Remote Car Starter
1. 5-button 2-way FM/FM LCD transmitter & one 5-button standard transmitter with "slide cover" to prevent accidental misuse.
2. New Manchester Encoder with 900 MHz transceiver for exceptional 2-Way communication range (1Mile Range)
3. Remote car starter with 5 on-board micro relays for reduced size
4. Plug-in super bright mini-BLUE LED
5. New 2007 GM non-starter wire compatible
6. SIS-11 super intelligent dual stage shock sensor, temperature sensor and paging knock sensor
7. Three auxiliary channel outputs programmable to momentary, pulsed, latched or timer control output.
8. Tachometer learning, voltage or timer start modes
9. Gasoline or diesel compatible with 10, 15 or 20 second "wait-to-start"
$260 Plus Shipping, Retail at $600!
Image 4 Channel Security System w/ 2-Way AM/AM LCD Remote Car Starter
1. One, 5 button 2-way AM/AM LCD transmitter with Titanium finish
2. NEW One, 5 button AM "slide-cover" mini-remote transmitter
3. NEW 2007 GM non-starter wire compatible
4. NEW Built-in, On-Board Temperature Sensor
5. Remote car starter with 5 on board MICRO K relays for 1st Ignition, 2nd Ignition, Starter, Accessory and Parking light flash
6. Door lock with "Comfort / Window" feature
7. Remote start "Turbo Timer" feature
8. Three hour, two hour timer start
9. Plug - in port for optional temperature sensor (Fahrenheit / Celsius)
10. Two programmable auxiliary outputs
11. Tachometer, Voltage, Timer start modes
12. Plug - in port for optional paging sensor
13. Gasoline and Diesel fuel compatible
14. LCD remote with vibrator mode and multiple chimes for confirmation
$180 Plus Shipping, Retail at $500!
trupowermotorsports
6 Channel Security System with 2-Way AM/AM LCD Communications
1. 5-button AM/AM 2-way LCD transmitter & 5-button mini-transmitter
2. 1-way AM Transmitting antenna & extended range receiver
3. Six on-board relays: Parking light flash, Door Lock/Unlock Dome light, Starter Disable & Trunk Release
4. Door lock with "Comfort / Window" feature
5. Two car operation with standard transmitter & LCD transmitter
6. Dedicated horn output
7. Hidden / silent alarm feature with paging alert to LCD
8. Auxiliary outputs programmable: Pulsed, Momentary, Latched, and Timed
9. Dual stage shock sensor
10. Additional plug-in sensor port
11. Remote sensor by-pass
12. Car locater from remote transmitter
$155 Plus Shipping, Retail at $400!
Image Four Channel Security System with Two-Way AM/AM LCD Communication
FEATURES:
1. Three Stage system programming
2. 2nd, 3rd & 4th channel outputs
3. 2nd channel with selectable pulsed, latched or timer output
4. 3rd&4th channel w/select latched pulsed, momentary or timer output
5. Keyless entry with on board relays
6. Programmable Pulse Timer for the door lock outputs
7. 2nd plug-in dual stage sensor port
8. Horn output with optional chirp delete
9. Dome light / illuminated entry
10.Optional pager output
11.Selectable factory security disarm
PROGRAMMABLE FEATURES:
1. Chirp confirmation (on/off)
2.Manual/Passive Arming (on / off)
3.Automatic Re-arming (on / off)
4.Arm voltage sense (3 sec./ 30 sec.)
5.Dedicated silent arm / 3rd channel
6.Horn chirp delete (on / off)
7.Lock / unlock pulse timer
8.Single / Double pulse unlock
9.Passive door locking
10.Ignition control door locks
11.Pathway Illumination
12.2nd channel pulse, latch, timer
13.3rd channel momentary, latch, timer
14.2-step unlock / factory disarm
$125 Plus Shipping, Retail at $350!
Image Three Channel Security System with Starter Disable & Dome-Light Output
1. Two, 5 button mini-style remotes
2. 56 bit random code hopping
3. Passive Arming By Pass / Remote
4. 150 feet transmitting range
5. Window Comfort Feature
6. Code learning / anti-scan receiver
7. Two car operational
8. EE-prom back up memory system
9. Remote Panic and Car Locator
10. Parking light flash (relay on board)
11. 2nd & 3rd channel auxiliary output
12. Dual polarity (+/-) door lock outputs
13. Plug-in valet/override push switch
14. Plug-in super bright LED
15. True last door arming
16. Starter disable w/relay & socket
17. Plug-in dual stage shock sensor
18. Dedicated horn output
19. Programmable 2-step unlock
20. Door lock pulse timer
21. 120 dB single tone siren
1. Chirp confirmation (on / off)
2. Manual/Passive Arming (on / off)
3. Passive arm door lock (on / off)
4. Ignition control door locks (on / off)
5. Automatic Re-arm (on / off)
6. Single/Double pulse unlock
7. Pathway illumination (on / off)
8. Arm voltage sense (3 sec / 30 sec)
$95 Plus Shipping, Retail at $250!
trupowermotorsports
Power Stop Brakes:
Image Integra (94-01) Front Package
This kit consists of 1 left rotor and 1 right rotor (cross-drilled) for the front as well as a pair of brake pads made for this vehicle. POWER STOP cross-drilled rotors will help eliminate brake fade and rotor warpage, as well as enhancing wet weather braking. After several stops, during spirited driving, and under emergency braking, they will out perform your original brake components.
$180 Plus Shipping
Image Integra (94-01) Rear Package
This kit consists of 1 left rotor and 1 right rotor (corss-drilled) for the rear as well as a pair of brake pads made for this vehicle. POWER STOP corss-drilled rotors will help eliminate brake fade and rotor warpage, as well as enhancing wet weather braking. After several stops, during spirited driving, and under emergency braking, they will out perform your original brake components.
$160 Plus Shipping
Image Integra (90-93) Front package
This kit consists of 1 left rotor and 1 right rotor (corss-drilled) for the front as well as a pair of brake pads made for this vehicle. POWER STOP corss-drilled rotors will help eliminate brake fade and rotor warpage, as well as enhancing wet weather braking. After several stops, during spirited driving, and under emergency braking, they will out perform your original brake components.
$180 Plus Shipping
Integra (90-93) Rear Package
This kit consists of 1 left rotor and 1 right rotor (cross-drilled) for the rear as well as a pair of brake pads made for this vehicle. POWER STOP cross-drilled rotors will help eliminate brake fade and rotor warpage, as well as enhancing wet weather braking. After several stops, during spirited driving, and under emergency braking, they will out perform your original brake components.
$160 Plus Shipping
We have many packages on sale so let us know what kinda car you got and we will check, that way we dont have to list them all!
trupowermotorsports
All Killerglass hoses on sale! Contact us for pricing!
KillerGlass is the worlds first illuminated clear radiator hoses for automotive use...
Watch your coolant flow like a lava stream during the day light it up at night! Thats right this is the hottest product on the market manufactured exclusively by KillerGlass and represented by CarSponsorship.com. Made of high tech clear Pyrex glass and mounted using sections of your existing hose on each end for flexibility with custom clamps. This bad boy lets you watch your coolant flow and lights it up at night for a bright red, blue or green glow with L.E.Ds impregnated in the glass. This will definitely score some serious points at shows!
Jezek
50% JDM
Post by Jezek » May 15, 2007
w0wzers.
blackhope121 wrote:...if cars were birds civics would be pigeons.
[/b]
trupowermotorsports
DEI/Cry02:
CryO2 Cryogenic Intake Systems:
Image CryO2 5 lb. Tank, Wiring, & Solenoid Kit
The foundation to every CryO² System. Must have this kit to utilize CryO² components. The kit includes a 5 or 10 pound Co² tank, cryogenic solenoid valve, all necessary fittings, 14 ft. stainless steel hose, full wide open switch, arming switch, and wiring kit. Only one kit is needed to operate all the CryO² components.
$288 Plus Shipping
Image CryO2 10 lb. Tank, Wiring, & Solenoid Kit
$310 Plus Shipping
Exhaust Wrap & Kits:
Image 1" x 50' Exhaust Wrap -$27 Plus Shipping
2" x 50' Exhaust Wrap- $43 Plus Shipping
1" x 15' Exhaust Wrap - Short Roll -$10 Plus Shipping
2" x 15' Exhaust Wrap - Short Roll-$15 Plus Shipping
1" x 50' Exhaust Wrap Black- $28 Plus Shipping
2" x 50' Exhaust Wrap Black-$46 Plus Shipping
Exhaust Wrap Kit - Black HT Coating-$110 Plus Shipping
Exhaust Wrap Kit - Aluminum HT Coating-$100 Plus Shipping
Image Turbo Insulation Kit-$82 Plus Shippng
1" x 15' Exhaust Wrap Black - Short Roll -$15 Plus Shipping
2" x 15' Exhaust Wrap Black - Short Roll- $15 Plus Shipping
Ties & Clamps:
Image Stainless Steel Locking Ties 8" (8 per pack)-$15 Plus Shipping
Stainless Steel Locking Ties 14" (4 per pack)-$10 Plus Shipping
Aluminized Materials Tapes & Sleeves:
Image Heat Screen (Aluminized Radiant Matting 36"x40")-$75 Plus Shipping
Image Versa-Shield (Univeral Heat Shield 7"x24")-$26 Plus Shipping
Image Heat Sheath (Aluminized sleeving - sewn) 3/4" x 36"-$15 Plus Shipping
Image Heat Sheath (Aluminized sleeving - sewn) 1-1/4" x 36" -$18 Plus Shipping
Image Heat Shroud (Aluminized Sleeving - Velcro) 1" x 36"-$27 Plus Shipping
Image Cool-Tube 3/4" I.D. x 3"-$25 Plus Shipping
Cool-Tube 3/4" I.D. x 15"-$68 Plus Shipping
Cool-Tube 1-3/8" I.D. x 15"-$16 Plus Shipping
Image Aluminum Plug Wire Sheath 3/4" - 6" (4 Pack)-$10 Plus Shipping
Image Heat Resistant Sealant, 3 oz. Tube-$16
Jezek
50% JDM
When will the madness end?!!?!?!?!?!
LOL
trupowermotorsports
Image Cool Tape Plus 2" x 60'-$65 Plus Shipping
Cool Tape Plus 1-3/8" x 30'-$26 Plus Shipping
Image Cool-Cover Air-Tube Cover (36" Long x 14" Wide)-$65 Plus Shipping
Kyowa Racing:
Please choose your color and size below. For an application guide, please visit: http://www.kyowadesigns.com/appGuide.html.
Image Kyowa KR206 - Set of 4 Rims
17x7 Black- $438
17x7 Hyper Black- $478
18x7.5 Black- $510
18x7.5 Hyper Black- $550
19x7.5 Black- $646
19x7.5 Hyper Silver - $686
20x7.5 Black -$800
20x7.5 Hyper Black - $840
Kyowa KR210 - Set of 4 Rims Image 17x7 Black - $438
17x7 Hyper SIlver-$478
18x7.5 Black -$510
18x7.5 Hyper Silver- $550
18x7.5 Hyper Black - $550
Kyowa KR228 - Set of 4 Rims Image 17x7 Black -$438
18x7.5 Black -$510
Kyowa KR316 - Set of 4 Rims Image 17x7.5 Gunmetal-$462
17x7.5 Black -$462
18x7.5 Gunmetal-$534
18x7.5 Black -$534
Kyowa KR518 - Set of 4 Rims Image 17x7.5 Black/Machined-$438
18x7.5 Black/Machined-$510
Kyowa KR566 - Set of 4 Rims Image 18x7.5 Black/Machined-$510
Kyowa KR595- Set of 4 Rims Image 17x7 Gold-$438
17x7 Gunmetal-$438
trupowermotorsports
Jezek wrote:When will the madness end?!!?!?!?!?!
LOL
We got tons more but this should be a nice start lol!
