PLX DEVICES:
iMFD Display Modules
DM-100 52mm OLED Universal Gauge w/ Control Box and RemoteThe iMFD DM-100 is a 52mm (2 1/16") universal gauge designed specifically to display a wide variety of automotive information far superior to that of a standard automotive gauge. The DM-100 can display up to 4 different sensors simultaneously and can be connected in a daisy-chain with up to 32 sensor modules and 32 other display modules.
Features Include:
# real time plotting
# customizable gauge styles, backgrounds, colors
# digital display
# organic LED
# set peak and hold points
# can display data from 4 modules at once
# simple to install
# PC interface software included
# comes with remote control
$210 Plus Shipping
52mm Wideband Air/Fuel Ratio LED Gauge in Black FaceThe PLX DM-5 AFR is a standard size 2 1/16" (52mm) LED automotive display designed to display the values measured from the SM-AFR. Measuring only 0.7" (18mm) thick, it can virtually be mounted anywhere. The DM-5 is designed to fit into most aftermarket 2 1/16" (52mm) cups, and mounts for seamless integration into your vehicle. This is an ideal accessory for your SM-AFR module. Up to 32 can be daisy chained together in the iMFD system.
$76 Plus shipping
52mm Wideband Air/Fuel Ratio LED Gauge in White FaceThe PLX DM-5 AFR is a standard size 2 1/16" (52mm) LED automotive display designed to display the values measured from the SM-AFR. Measuring only 0.7" (18mm) thick, it can virtually be mounted anywhere. The DM-5 is designed to fit into most aftermarket 2 1/16" (52mm) cups, and mounts for seamless integration into your vehicle. This is an ideal accessory for your SM-AFR module. Up to 32 can be daisy chained together in the iMFD system.
$76 Plus Shipping
iMFD Sensor Modules:
Air/Fuel Ratio Sensor Module w/sensorSM-AFR accurately measures the precise air/fuel ratio (AFR) of any internal combustion engine. Up to 32 SM-AFR modules can be daisy chained together in the iMFD system. SM-AFR can also be used as a stand alone unit capable of interfacing with 3rd party hardware. All Sensor Modules are housed in high quality extruded aluminum designed to operate even in the most extreme conditions. In addition, all SM modules offer outstanding digital accuracy, response and resolution which far exceeds that of a standard gauge.
$161.50 plus shipping
Air/ Fuel Ratio Sensor Module w/o Sensor
$130 Plus shipping
Wideband air/fuel ratio products:
R-500 Wideband Computer Kit w/EGT ProbeDesigned for the advanced tuner, the R-500 combines 3 essential parameters (Air/Fuel, EGT, Knock) of internal combustion engine tuning into one! Whether you're on the dyno, track, autocross, street or drag strip, the R-500 can be fully customized to suite your individual application. With intuitive user menus packed with features, merged with powerful PC software, there is virtually nothing that the R-500 can't do.
Features Include:
# Measures Air/Fuel Ratio, EGT, Knock, and Boost
# Integrated 6 Inputs for data logging (2 Speed, 4 Analog)
# 90 minutes of onboard memory for recording and PC download
# Integrated "Real-time dyno." Measure your HP, TQ without expensive trips to the dyno.
# 4 analog outputs (User configurable) for 3rd party interface
# Replace your stock narrowband sensor.
# Fully customizable LED warning light or shift light
# High speed USB 2.0 interface
# Powerful 32 bit integrated processor, RAM, and FLASH technologies
# 100% backwards compatible with M-Series controllers
# Compact dash mountable design (4.75 x 2.25 x 1 inch)
# Powerful PC analysis software included
$500 Plus Shipping
R-500 Wideband Computer Basic KitDesigned for the advanced tuner, the R-500 combines 3 essential parameters (Air/Fuel, EGT, Knock) of internal combustion engine tuning into one! Whether you're on the dyno, track, autocross, street or drag strip, the R-500 can be fully customized to suite your individual application. With intuitive user menus packed with features, merged with powerful PC software, there is virtually nothing that the R-500 can't do.
Features Include:
$460 Plus Shipping
R-300 Wideband Computer Basic KitThe R-300 is a compact, dash mountable, easy to use wideband air/fuel controller with powerful data logging capabilities. Wideband air/fuel ratio can be monitored in numeric, gauge or graphical form. Data logger inputs can be fully customized to display virtually ANY type of data. It's like combining 6 gauges into one! The R-300 can store up to 90 minutes of logged data and 99 individual sessions for later PC download and analysis with PLX Logger PC software.
# Measures Wideband Air/Fuel Ratio
# Integrated 6 Inputs for data logging (2 Speed, 3 Analog, 1 AFR)
# Analog outputs for 3rd party interface
# Sensor soft start circuitry, prolongs o2 sensor life
$365 Plus Shipping
Wideband Oxygen Sensor Controller with DisplayThe M-Series Wideband Oxygen Sensor Controllers are extremely simple to use and to setup. They do not require complicated sensor calibration procedures nor do they require any confusing software setup. Simply, connect the power wires to a 12V source, snap the sensor wire harness with the oxygen sensor and you're ready to start measuring your automobile's air/fuel ratio within minutes! PLX Devices widebands are guaranteed accurate to 0.1AFR with race proven technology which yields extremely fast reaction times.
# Works with standalone engine management systems. Accurate Air/Fuel Ratio < 0.1, Fast Reaction
# Advanced Sensor Self Calibration Circuitry. No manual calibration required.
# Wideband LINEAR Analog Output (0-5V)
# Narrowband Analog Output (0-1V)
# Replace your stock Narrowband sensor.
# 32 MHz Advanced DSP Technology
# Built in Resettable Fuse (No external fuse needed)
# Sensor soft start circuitry, prolongs o2 sensor life.
# Compact and Professional Design
# "Plug and Play" Installation
# ISO 9002 Certified Assembly
$275 Plus Shipping
Blackline GPS:
GPS SnitchChanging the way you protect your vehicle, the GPS Snitch is a purpose-built wireless vehicle security and tracking solution. Small enough to be hidden almost anywhere, GPS Snitch gives you the power to locate your vehicle on demand using the internet or web-enabled cellular phone.
To learn more about the Blackline GPS "Snitch", please visit GPS Snitch.com.
Features include:
# Real-Time Tracking
# On-Line Interface
# Mobile Interface
# Nationwide Coverage
# Alarm Notifications
# Alert Types Motion Alert and Security Perimeter Alert
# Notification Methods- Text message to mobile phone and e-mail
# Remote Arm / Disarm From Mobile Phone
# Speed and Direction Reading
# Location Request Response Time- Typical 30 to 45 Seconds
# Location Request Response Time- Optimal 10 to 15 seconds
# GPS Tracking Sensitivity -155 dBm
# Internal Motion Sensor
# Rechargeable Battery Inside
# Recharging Time 4 to 6 hours
# Standby Use Time- 7 days
# Typical Use Time- 4 to 5 days
# Optional Hard-Wiring Kit
# Connector DC jack
Note- There is a one time activation fee ($29.99) as well as a monthly service plan (as low as 14.99 per month) with this product. This is not included in the cost of the price.
The Snitch requires GSM coverage. Please check with your cellular provider.
$300 Plus Shipping
H1-$250
ORACLE Halos are the best Demon Eye kits produced for any vehicle. Do not mistake this product for some “do it yourself” knock off Demon Eye Kit. This is a high quality product produced by the new leaders of the industry, Advanced Automotive Concepts (AAC)! This kit uses Cold Cathode technology, which can be seen vividly, even in direct sunlight! It is better than LED or fiber optic kits. The rings are rated at 50,000 hours of continuous use, twice the lifespan of competition! The fitment for the vehicle is up to OEM standards.
6 Channel Security and Remote Car Starter System with 2-Way FM/FM OLED* Transceiver
6 Channel Security System with 2-Way FM/FM Remote Car Starter
4 Channel Security System w/ 2-Way AM/AM LCD Remote Car Starter
Four Channel Security System with Two-Way AM/AM LCD Communication
Three Channel Security System with Starter Disable & Dome-Light Output
Integra (94-01) Front Package
Integra (94-01) Rear Package
Integra (90-93) Front package
CryO2 5 lb. Tank, Wiring, & Solenoid Kit
CryO2 10 lb. Tank, Wiring, & Solenoid Kit
1" x 50' Exhaust Wrap -$27 Plus Shipping
Turbo Insulation Kit-$82 Plus Shippng
Stainless Steel Locking Ties 8" (8 per pack)-$15 Plus Shipping
Heat Screen (Aluminized Radiant Matting 36"x40")-$75 Plus Shipping
Versa-Shield (Univeral Heat Shield 7"x24")-$26 Plus Shipping
Heat Sheath (Aluminized sleeving - sewn) 3/4" x 36"-$15 Plus Shipping
Heat Sheath (Aluminized sleeving - sewn) 1-1/4" x 36" -$18 Plus Shipping
Heat Shroud (Aluminized Sleeving - Velcro) 1" x 36"-$27 Plus Shipping
Cool-Tube 3/4" I.D. x 3"-$25 Plus Shipping
Aluminum Plug Wire Sheath 3/4" - 6" (4 Pack)-$10 Plus Shipping
Heat Resistant Sealant, 3 oz. Tube-$16
Cool Tape Plus 2" x 60'-$65 Plus Shipping
Cool-Cover Air-Tube Cover (36" Long x 14" Wide)-$65 Plus Shipping
Kyowa KR206 - Set of 4 Rims
17x7 Black - $438
17x7 Black -$438
17x7.5 Gunmetal-$462
17x7.5 Black/Machined-$438
18x7.5 Black/Machined-$510
17x7 Gold-$438
