HID opinions
robry
70% JDM
Post by robry » January 18, 2007
6000k, they are broken in now and have a bit of purple in them. the 8000k will be bluish/purple/white, I wouldn't recommend those. It's between the 4300k which will be pure white, and 6000k which has the purple hue/tint.
tommybanzai
25% ricer
Post by tommybanzai » January 18, 2007
Robry, I don't understand why you needed to use this(you sent to me via myspace:
"The kit is great quality, works absolutely perfect, even has a harness w/ fuse and relay, so it doesn't draw power from the factory harness."
I know your kit works fine, as I have been blinded by the light before. Is it just because the purevision kit draws a lot of power through the factory wiring that you ad to use it?... it's one thing I have learned reading up on these. That certain kits will/will not place excess draw on your factory wiring. And usually it is just for the initial start up that the current is high (maybe first >1 second). I noticed the company/guy you directed me to has both purevision and techone...why did you get the purevision?..solely price?...or should I just call and ask him personally?
i.e.: I been looking at the Techone kit more and more. It has a lot of +'s I feel good about.
" This HID kit has everything you need. You get the HID Xenon bulbs, ballasts with integrated igniters, wiring harness, zip ties, mounting plates, mounting screws, and installation instructions. These kits were designed to be plug and play so there will be no need to cut, splice, or solder anything together! 100% compatible with your car's OEM wiring and literally takes 5-10 minutes for even a beginner to install. Better yet, all components are weather-proof, but the biggest and best feature lies with the ballast. Unlike OEM ballasts, the Techone ballasts only draw 7.5A upon startup for the first 3 seconds, then only 3A while running! This makes it safe to use with OEM wiring WITHOUT THE NEED FOR AN UPGRADED HARNESS! This saves you tons of time, hassle, not to mention a much cleaner looking engine bay and saves you $50!"
Thanks again robry and others...your input is appreciated greatly!!!
STEELCITYEVO8
Post by STEELCITYEVO8 » January 18, 2007
get them u will appreciate the difference. far better than normal lighting!!
Rally Red evo VIII/ GT3076R/ AEM EMS/ EXEDY TWIN DISK/ HKS 272'S/420WHP/337LB.FT BUSCHUR TUNED/[email protected]/ http://www.racerswanted.net/
tommybanzai
25% ricer
STEELCITYEVO8 wrote:get them u will appreciate the difference. far better than normal lighting!!
Got them...ordered a set today
Post by Nikku » January 19, 2007
tommybanzai wrote:Which one you have?
before i moved to japan i had a tl on which HID was standard. it was a wonderful difference.
