such bad luck....
mcmBuilt
Post by mcmBuilt » May 23, 2006
sorry bro that sucks, but don't ever give up
miyagi
Post by miyagi » May 23, 2006
had to sell the wideband to fund the last rebuild (was planning on buying one next week or so...) .... and didn't have the EGT hooked up because i've been planning on getting rid of it anyway .... I had an air/fuel gauge in there, but it went haywire on me a few weeks ago,and is stuck on the last bar of rich
So this next one isn't going to even start up until there's a wideband in there so i can keep in check...
the motor gets torn apart tomorrow .... me, darren and 2 buddies went down to the shop at like 9 and pushed the car back in the garage, ripped everything off and pulled the motor out and cleaned up to get ready for tomorrow ... we would have done more, but i had to pick duanne up from work at 11 and darren promised the ol' lady he'd be back at like 9:30/10.
I'll keep you guys posted
1990 Accord EX Sedan
All stock, All the time
money in the baaaank
urbanracer2000
Post by urbanracer2000 » May 23, 2006
What do your datalogs show, that should tell you a little of what was going on.
Could you post your timing map?
No disrespect to Hybrid, but forged internals just don't take a shit at 350whp, not even eagle rods.
vtecdood
Post by vtecdood » May 23, 2006
urbanracer2000 wrote:What do your datalogs show, that should tell you a little of what was going on.
The car was tuned very conservative to due to the fact that there was a boost creep issue at top end, that is the reason the car didnt make as much power with a bigger bore than before. If you need a timing map im sure denis would supply it because as stated there was an issue so tuning was very conservative matt knows this and so does his friend from metricmotorsport who was with him when the tuning was done. So as stated before I believe there are other issues at hand here other than blaming the tuner.
urbanracer2000
[/quote]The car was tuned very conservative to due to the fact that there was a boost creep issue at top end, that is the reason the car didnt make as much power with a bigger bore than before. If you need a timing map im sure denis would supply it because as stated there was an issue so tuning was very conservative matt knows this and so does his friend from metricmotorsport who was with him when the tuning was done. So as stated before I believe there are other issues at hand here other than blaming the tuner.[/quote]
Is it possible that the injector on no.4 is bad?
If you guys have total confidence in the tune, what do you attribute the problem to?
How does the cylinder look, detonation or lean?
vtecdood
How does the cylinder look, detonation or lean?[/quote]
my guess is 2 things injector or the fact that the car would not hold consistant boost top end so what happens when you go race on a conservative tune and knowing that the boost was not holding steady top end.
But with the compression numbers being inconsitant that has me wondering there also.
Really there are many issues at hand here but I'm just saying not to point the finger at the tuner right away before knowing all the information wich is why i said there are other issues at hand other than tuning, Sorry if I have said too much matt.
urbanracer2000
This why I suggested the datalogs a few post back, to see where boost was at in relation to everything else.
It seems as though some stuff is not to be discussed in the open.......so I'll leave it at that :?
30stones
40% JDM
Post by 30stones » May 23, 2006
Matt i know your sorta straped for cash just so you know i have some if you need it i know 9 times outta 10 you wont take it but its there if you need it....i just want to see this bitch run for more than a week
97 Coupe
83mm GSR w/ GT30R turbine
403whp 297tq @ 16psi
Hybridynamics.com
Builtmotorsportswear.com
Post by munster » May 23, 2006
Any idea what happened yet? Are you guys still tearing down?
30stones
40% JDM
Post by 30stones » May 24, 2006
I dont know the details but i talked to darren and he said piston 4 has a hole in it...ill let matt or darren take it from there....... :cry:
