ACT clutch and flywheel install (B series)
step by step diy guides.
Post by munster » October 26, 2003
Image First thing you need to do is seperate the tranny from the block by removing the starter, all plugs that are connected to the tranny, the dust guard on the bottom of the motor, and the various bolts holding the two pieces together. The bolts run both ways (some from the block to the tranny and others from the tranny to the block). The easiest way to seperate the two would be to have a rack and tranny jack, but I did it on the floor. Pick up the motor with the tranny and move it side to side to seperate it a little. Then use a large screwdriver to get the tranny off of the dowels on either side of the block.
Next you need to remove the old clutch and flywheel. Using a 12mm (I think) 12 point socket in a criss-cross is the best way to relieve pressure on the springs to allow you to get the pressure plate and clutch disc off.
When removing the flywheel put some large allen wrenches through the bolt holes to the block so it doesn't move. Take these bolts out with a 12 point socket too and use a criss-cross pattern. Don't drop the flywheel on your finger like I did. It sucks.
Image Lay out your new clutch so you can make sure you have everything and reverse the process to install the new one. I didn't have to replace the throwout bearing, but once you have everything apart you'll see how to remove the arm.
Image Image Image Torque the flywheel bolts to spec.
Use the clutch alignment tool to center the plate to the flywheel and hold it in place while you bolt up the pressure plate and torque the pressure plate bolts to spec.
Image Image Align the shaft by rotating the crank counterclockwise and push the tranny back onto the dowels. Put your starter and all of the plugs back on, and you're in business.
I ran through this pretty quick, and I hope I didn't miss anything. Feel free to add any other tips if you want.
Post by tenchu » October 27, 2003
god damn ur going all out
alexsracing
60% ricer
Post by alexsracing » October 27, 2003
nice how to 8)
d16z6 turbo crx 12.6 @ 111 spinning 1st and 2nd
eclipse 14b turbo
jdm delivery
Post by jdm delivery » October 27, 2003
damn munster your a mechanical genious. lol by the way did that iced tea come with your clutch setup?
Post by munster » October 27, 2003
That was a necessity to the completion of the ACT clutch and flywheel install.
littledevil666
80% ricer
Post by littledevil666 » January 16, 2004
If your frum johnstown every project you do Iced Tea frum Galliker's is a necessity.
ban
Post by ban » October 05, 2004
hey munster,
don't forget to mention if your doing this on the floor of a garage with no hoist or stands... u'll need to invest in a friend to lift the tranny and in some blocks of wood or possibly a bolder to hold the tranny side of the motor high enough so the tranny can mount straight without hitting the floor... also the 2nd person should hand crank the motor so the shaft splines line up...these few things will make life easier when u dont have stands and lifts......
Agent Boost
80% ricer
Post by Agent Boost » March 14, 2006
it should be also noted that you need to pull the axles?
'00 EM1 - 400whp / stock sleeve b16 / 93 pump - SC61'd by Precision, Neptune'd by J. Evans.
Post by munster » March 15, 2006
Agent Boost wrote:it should be also noted that you need to pull the axles?
IF they were there I would have pulled them.
kidkombo
Post by kidkombo » April 03, 2006
munster your pics are down =(
RIP JOSELITO LITO BARBER HPL 4 life homie
[team2tO][TRIKspeed][EKsquad][fusionX]
email [email protected]
aim twOtoEdEK
smokey 2.0L[/b]
