weird steering feeling
tomoyasu
Post by tomoyasu » August 03, 2006
me and some friends went on touge tonight. and i bassically hate my car. its fucking sloooow compared to the other guys.
Anyways, when i was taking corners, the steering felt almost "slippery" i guess. the shit is weird ant it pisses me off.
What chu fools think it is? old shit that needs replacing? different tires? stiffer chassis? combonation?
Post by kotomile » August 03, 2006
Is there a tug at the wheel when you get on the gas/ let off/ brake?
tomoyasu
no, not that i noticed
Post by Sean @ NDF » August 03, 2006
I'm not sure what you mean by slippery?
Do you have power steering? Are your tires squealing/breaking traction?
tomoyasu
nope no power steering, no i wasnt breaking traction on every corner. but even on the ones i didnt it felt weird.
vtecdood
Post by vtecdood » August 03, 2006
Check to see if all your wheel weights are still intact and check the upper and lower ball joints and bushings. With you car being a 91 you could probably use a eurethane bushing kit if not already invested in.
builtmotorsportswear.com
jdmland.com
vtecdood wrote:Check to see if all your wheel weights are still intact and check the upper and lower ball joints and bushings. With you car being a 91 you could probably use a eurethane bushing kit if not already invested in.
right,
anyway you could describe the feeling better than slippery?
01teggy
Post by 01teggy » August 03, 2006
expain "slippery" a little better and what kind of suspension u got on ur ride?
can i get xtra mater on that!!!!!!!!
tomoyasu
i suppose slippery was a bad term to use. cuz im not sliding. i guess it just feels loose. not stiff maybe?
im guessing its just my weak ass suspension setup.
