Rear mounted turbo's. Looks like a clusterfuck more then anything else.
http://www.jlturbo.com/eyecandy.htm
Thoughts on this......
- boostjunkie95
- Secret Squirrel
they work pretty well on large displacement applications where the engine can spool the turbo (even a rather large one) without any difficulty...
they even have some uses in smaller displacement engines that just don't have the ROOM for a conventional setup
Of course a conventional setup is a more practical in most applications, there are advantages to this type of setup (when properly executed of course) in the right setup however
-less underhood heat from the turbo
-retention of stock exhaust manifold/header designs in applications like v6's/v8's that pose issues with traditional single turbo applications
-low cost
-easy install
there are obvious disadvantages also
-slower spool on smaller engines
-higher throttled volume and increased pressure drop
- location of turbo necessitates need to actually PUMP oil from the turbo oil drain back to the oil pan
-low cost
-easy install
finally turbo!
