EK to EG??
EK to EG??
Wiiill EK Coupe suspension fit on a EG hatch????
PLEASE PLEASE PLEASE SAY YES!!!!
- idreamidrive
- Sean @ NDF
- spock_rocker
- 95% ricer
the front strut forks i believe are different and i know for a fact the rear LCAs are different. now the DC and EG chassis are the same!
AIM = Hangoroshi Omoi
http://www.MemoryFab.com PM me if you need anything
B20 powered Gu'ripu Kaijuu!!
...TeamSloth:htolSmeaT...
The front shock forks are identical as are the mounting holes. The fronts are never a problem. In order to get the rear to fit you need to change out the lower shock mount bushing - the center one in the contrrol arm.
The EG runs a longer bushing so you'll have to press it out and run the shorter EK bushing. That is the only difference.
I'm not happy unless you're not happy.
correct..i'm running eg/dc2 struts on my ek. Fronts fit perfect, Rears i used washers in between the fork and the bushing due to the thinner bushing/wider fork.phunhaus wrote:The front shock forks are identical as are the mounting holes. The fronts are never a problem. In order to get the rear to fit you need to change out the lower shock mount bushing - the center one in the contrrol arm.
- SingleCamEJ8
this guy is very knowledgble...and provides great informationphunhaus wrote:The front shock forks are identical as are the mounting holes. The fronts are never a problem. In order to get the rear to fit you need to change out the lower shock mount bushing - the center one in the contrrol arm.
ebrake cables are different too
1.870 60ft [email protected] 225/50 R15 BFG drag radials, full interior.
builtmotorsportswear.com
jdmland.com
jdmland.com
nizzan1984
srry for the randomness. but i didnt know u were on here?!?!:o
"God invented turbo lag to give the domestic guys a false sense of security."
jdmcivic98 wrote:Jewish Domestic Market
*CACKYWHEELS
- Approved Vendor
This guy's obviously never put an EK suspension setup onto an EG, so don't listen to himspock_rocker wrote:the front strut forks i believe are different and i know for a fact the rear LCAs are different. now the DC and EG chassis are the same!
The other guy is correct the fronts mount up exactly the same, and the rears require a 3MM washer or so since the bushing on the EG LCA is a little thinner than the EK LCA.
