d series cam ? need everyones help on this one.
ok i did a full build on my y8, and the head was built when i bought it. it has a crower stage 2 cam and springs and pep valves. mild port and polish. i just out a 16g on my engine and it pulls hard but not how it should. im running 2.5" turbo back exhaust. obx intake manifold with velocity stacks, 2.5" charge pipe. 30x8x3 fmic, tubliar turbo mani. so the flows good and even.
i called hybrid and talked to dennis and he said to get that crower cam out of there and get a stock y8 cam. gimme opnions about this. "i belive him cause he does this shit daily but would too much lift cause a power loss like that."
if the case is that i gotta get rid of the crower ill trade it for a stock y8 cam and $.
please reply.
please reply.
- race2win502
ill re time it tomrmow and see what happens. hopefully it works, if not theres a kid from pittspeed who has a stock y8 cam and 150$ for that crower. hopefully its out of time a tooth, the fucker should rip now with the 16g on it., ill give it a shot with the timing and keep you guys updated.sikblugsx wrote:try timing it first(your usually off a tooth)
- CivicSpoon
Timing it to stock spec isn't going to help. The cam needs to be adjusted on a dyno to show what degree of retardation or advance it will make the most power. Any aftermarket cam should be done this way, turbocharged engine or n/a. With a turbo cam on the other hand, they should be set to stock (no advance and no retard), or at least somewhere close to stock; to make the most power.
