Ya I know, blurry and dark..............
in the garage. too small.........
the powerplant:thumbup:
BTW: The car in the background is my friends cammed and itb'ed k20a2 eg.Here is a little mod list of my car:
MOTOR
K20a
DTR 4-2-1 SS header
2.5 inch custom piping
3in vibrant street power flat black muffler.
Hondata IMG
Walboro 255 fuel pump
Aem fpr
Golden eagle fuel rail
Hybrid Harness
Kpro
Karcepts box
Hasport EKK2 mounts
CAI
Exedy stg 1 clutch
Act lightweight flywheel
Revo short shifter
Suspension and Brakes
GSR brakes front and Rear
Earls stainless steel brake lines
Omni Power coilovers
Omni Power rear lca's
Weapom R x-brace
Exterior
JDM thin side molding
Shaved emblems
CTR style grill
Red/White tails
1 set of polished GSR "Blades"
1 set of flat black GSR "Fat Fives"
1 set of white "Hx's"
Interior/Ice
CTR manual door panels
GSR gauge cluster
Air Bag block off plate
A/C block off
Single din radio block off
Integra LS front cloth seats
Del Sol "red stripe" seats, uninstalled
Si rear seats
Black Carpet
Broadway mirror
Black/Gray lil' Recaro cell phone holder
Optima Yellow Top
Panasonic cd player
Panasonic speakers.
Next on my list for the motor is a koyo or fluidyne radiator, electric fan, some more grounding, and an oil catch can. And then most likely cams, rbc, new axles, and injectors this summer.
Next for the body is a full wet sand/buff/polish, either an ex or sir front lip, ctr or si rear lip, sir headlights, 8000k h.i.d. kit, 3000k h.i.d. fog kit, stanley yellow fogs, and window visors. Then later down the road a carbon hood and maybe carbon trunk, spoon/visoin cf mirros, 16in white sprint hart cpr's?, and sir bumpers?.
Interior is up in the air depending on if i gut it or not(black powder coated 6 point auto power cage).
For brakes all I really need now are pads and some slotted rotors.
Suspension is my #1 priority before spring, as i plan on auto x'ing the car regularlly. Im thinking asr rear subframe support, 32mm rear sway bar, beaks endlinks and lower tie bar, front lca's, energy suspension bushing's, front sway bar?, and maybe a bolt in auto power cage, and most likely a change to pic or tein susp, and alot more.
Anyways all comments welcome on the car, and my setup. Input also welcome.
And btw the pictures were taken by my friend Sebastian at lower wacker, and i think i should add that there was a bum sleeping behind the green dumpster in the 5th pic, i know this because my friend went to pee, but the bum yelled, just before he would of got hosed. Also that orange hatch that I mentioned, has recently blown up, and now he has a new setup in the works, k24 with a 2.7 stroker kit, nitrous, itb's, etc..........
