All parts with no price MAKE OFFER, NO resonable offers will be refused Lowballers are welcome here! Just need to get this stuff out of my garage. Need to make room/fund my new engine build.
More parts will probably be added once found, Bump if you view!!
NEW PARTS PICS WILL BE UP TOMORROW!!
I am Paypal Verified, Located in Pennsylvania
NEW PART -01 B18c1 GSR Crank Pulley with bolt and key
NEW PART -01 oem GSR Alternator with top and bottom bracket
NEW PART -01 oem GSR Distributor
NEW PART -01 oem Complete GSR Intake Manifold with all sensors, vacuum box, throttle body and everything
NEW PART -OBD2A to OBD1 ecu jumper - Excellent working condition - $45.00 Shipped[/B]
-D16y7 Longblock 180k miles lost oil pressure no block damage or broken parts - $50.00 PIC BELOW
-D16y7 Flywheel
-D16y7 Alternator - PIC BELOW
-D16y7 Starter - PIC BELOW
-D16y7 Distributor - PIC BELOW
-D16y7 Flywheel Cover/Tranny Brace
-D16y7 ECU
-D15b8 Longblock 151k miles Ran perfect when pulled 8 valve head 16 valve releif pistons-Pretty much block/head no manifolds or anything. - $50.00 PIC BELOW
-D15b8 Alternator
-D15b7 Tranny out of 94 del sol 4.0 FD Need input shaft bearing - PIC BELOW
-D-series Shifter Linkage -96 ek hatch - complete with shifter.
-(1) Set D-series Axles - driver/passenger Good Condition
-D series Tranny T-Bracket - PIC BELOW
-(2) D series A/C Brackets - PIC BELOW
-P30 A/C Bracket - PIC BELOW
-PR3 A/C Bracket - No Tensioner - PIC BELOW
-(3) D series Front Tranny Torque Mounts Bracket - PIC BELOW
-B18b LS COMPLETE A/C System - Everything up to firewall
-D16y7 COMPLETE A/C System - Everything up to firewall
-2 1/2 inch High Flow cat, used unknown name
-Del Sol oem taillights
-1992 Civic 4dr oem spoiler
-96-00 Civic DX oem Suspension complete shocks springs forks and tophats all assembled - SOLD
-2001 GSR OEM flywheel - SOLD
-(2) GSR P72 A/C Brackets - BOTH SOLD
-(1) B series Front Tranny Torque Mount Bracket - SOLD
-Apexi VAFC verison 1 No mount or pigtail harness, good working conditionSOLD
-2001 B18C1 Block Girdle - Main Caps,bolts, oil pickup,windage tray and oil panSOLD
-92-95 Chipped obd1 p06 ecu non vtec, zif socketed - $75.00 SOLD
-D series 92 civic si shifter linkage SOLD
-Garrett T3/T4 57 Trim .63 a/r Minimal Shaft Play 4 Bolt exhaust - SOLD
-XTD Stage 3 Clutch D series Used 137 miles - SOLD
- B-Series JG Edelbrock ProFlo Header w/ or w/o Race b-pipe - SOLD
-01 B18c1 GSR Timing belt covers complete with hardware - SOLD
-2001 GSR Engine mounts - 3 bolt drivers side with engine bracket, Rear T-Bracket,Top Tranny mount - 88k miles - SOLD
-01 oem GSR vtec solenoid - broken pressure switch plug SOLD
-01 Usdm GSR Valve Cover-MINT no Plug cover - SOLD
D16y7 Engine
Gsr Mounts/T bracket/a/c Brackets
B series a/c brackets/Tranny torque brackets
D16y7 Alternator/Distributor/Starter
D15b8 Engine
D15b7 Tranny/96-00 ek stock suspension
P06 Ecu and JUmper Harness
Gsr Intake Manifold/Valve Cover
Gsr Alternator and Brackets/bolts
Gsr Obd2b Distributor
JG Header
