Bought this used from somebody on another forum, it was bent on the top and bottom (slightly), but no cores are messed, the only part that was bent are some fins and the end pieces. Wont suffer any boost leak from it! So basically its brand new, was never used on any application, I test fitted it WITHOUT using the threaded bungs. Just sat on a jackstand. Anyways, Not boosting for awhile, need money to build the motor first...then I'll worry about boost products.
90$ Shipped
Heres some pics from test fitting
And the IC
Anyways, again, never used. Will look awesome if used. Supported up to 600+ hp.
