Feels like clutch is slipping but its not??
First i have to say that this problem is intermittent. But when it does happen it feels like my clutch is slipping but its not because i can rev it up to 8k and shift and it grabs like mofo. It seems to only happen between 1-3 or 4k once i go higher than that its fine? Have any ideas what i should check?
Championship White EM1
it still may be your clutch slipping, just the early signs of a burnt clutch. try this:
at idle, with the E-brake pulled, no obstructions in front of you, and the clutch pedal fully depressed, ...put the car into 4th gear and let the clutch out all at once. The engine should stall immediately without hesitation. if it turns over once or twice before stopping your clutch may need replaced.
Rodney Wills wrote:the fashion of racing is the function, so as long as you have a properly functioning vehicle, it'll never go out of style
- jdm delivery
- 95% JDM
- Location: Somewhere around Barstow on the edge of the desert.
- Sean @ NDF
- jdm delivery
- 95% JDM
- jdm delivery
- 95% JDM
