90-93 integra radiator install
fourth generation civic & crx tech. [84-91]
Moderator: Nikku
Post by Nikku » December 29, 2003
the pix below will explain it all, the only thing necessary to have is a 88-91 CRX Si driver side radiator mount bracket (the top one, it is shaped like a triangle).....on a related note, the radiator sits perfectly w/ no possibility of air in the head (which can be caused if the upper port of the radiator sits too high above the head).....enjoy
stock
Image integ unit
Image nice new fan that flows ALOT more CFM then stock and can be had for about $60 at your local autozone, that one is a HAYDEN fan
Image installed
Image another install shot
Image side install shot, notice how straight the upper coolant hose is (IE not angled up and down)
Image bay shot
Image all legal baby
g2JDMteg
Post by g2JDMteg » December 29, 2003
wow that fits nicely, what are you using for you upper rad. hose?
Team 1320
g2JDMteg wrote:wow that fits nicely, what are you using for you upper rad. hose?
that is a piece of flex hose from kragen....works well and does not swell nearly as much as the OEM hose, works really good w/ the spoon radiator cap
