Sean @ ESG wrote:i dont get it, this is some wisconsin shit
Note the valve stem. It's not the rubber type, it has inner and outer o-rings, a retainer washer inside and then two nuts that lock. When installed it's rigid, not like a "normal" valve stem which you can push around.It's cool, but there's zero info on how they work. No instructions with the wheel, nothing online. I should probably MS Paint an instructional diagram.
