need some d16y7 help...
nizzan1984
ok well i am gonna clean my air idle control valve but im not really sure where it is and what tools i need to take it off. if anyone has a pic of where it is located on the d16y7 td thad be great! thanks in advance... (again lol):mrgreen:
"God invented turbo lag to give the domestic guys a false sense of security."
jdmcivic98 wrote:Jewish Domestic Market
its on the throttle body it has a cream colored plug 3 wire to be exact. remove the 4 phillips screws i think either that or 12mm bolts. but remove your TB it makes it so much easier. if your carefull you can re sude the gasket they usually come right off without tearing.
nizzan1984
hondalowlow wrote:its on the throttle body it has a cream colored plug 3 wire to be exact. remove the 4 phillips screws i think either that or 12mm bolts. but remove your TB it makes it so much easier. if your carefull you can re sude the gasket they usually come right off without tearing.
yea, well we found the problem after taking it to a shop. ended up being acouple wires behind the dash that caused it to idle weird, and make the a/c short out. it finally works tho!!!:-D
nizzan1984
