Its about damn time!
hmm im not sure what to do. i got a little bit of money, not sure if i want to buy some sleeve coilovers, Honda access window visors (im a smoker, so they help. plus my windows suck) or just save the money and get a good set of full coilovers next month....any opinions?also, i guess ill just turn this into my build thread, so i'll be posting updates from here on out
Go for the Full Coilovers.
Doing things twice sucks.
TEAM MCM
http://WWW.BUILTMOTORSPORTSWEAR.COM
http://www.myspace.com/builtmotorsportswear
http://WWW.BDLINDUSTRIES.COM
"It's not what you say, It's what you do."
yup. not gonna get coilovers till its closer to spring. no point to get them when its about to be winter and ill be keeping it at the same height.
i did order a couple small things though. AVS window visors. the honda access ones are 4 times as much as these ones. broadway mirror, JDM squash air freshener, and HAMP synergy oil filter for my oil change next weekend.
ill post new picks when i get that shit on!
Also, i tried fixing the windows...but couldnt get the door panels off? i can get the bottom portion undone but not the top. i tried to work on the HVAC controls too. switched them out and got some lights working, but i didnt see the cable to switch vent types.
were there no cables attached to the HVAC unit? did you see a spot on the new one to attach cables? That may be the problem.......getting ED door panels off is a royal pain. make sure you remove all the hidden ass screws from them, then you should get something like a chisel to kinda pry it off safely (which is what the SM even recommends). it will take time and patience.
