**Top Secret 07'/08' project has begun!**
miyagi wrote:junk that dc header while you're at it too. Get an edelbrock.
Thanks guys! j/k30stones wrote:dc = garbage. bang for the buck get the edelbrock header. it looks nicer too
Well the dc header i have imo is not a shitty one it is the ITR copy, stainless steel 4-1 1 peice with the 2.5 inch collector which would yeild much better high rpm power than the edelbrock as it is.
The edelbrock is deffinately newer and looks nicer...even with the 2.5 inch collector mod who knows how much better/worse numbers it would make over the dc or if it would even be worth it. I've never seen dyno comparisons between the two so i cant say which is better. I would use the dc if it were my car..
Either way i offered jude the edelbrock and he wants the dc, let me know if plans change yo
1996 VSM Civic Dx Hatch - Sold
1990 Crx Si - Sold
1994 Accord ex DD
1990 Crx Si - Sold
1994 Accord ex DD
sorry man wasnt trying to cheat you out of a sale. I didnt know it already had the 2.5 collector he didnt state that it was the "JDM" Type R header. As for mdding the edelbrock, edelbrock is a copy of the SMS so when you give it the 2.5 inch mod you basically got a SMS header. the integra is a goof off car and if I am spending a grand on an exhaust manifold there will be a snail hanging off the bottom
. Summit had the edelbrock stainless header for 169 shipped at the time i bought it so thats why i went that route. I think Jude should man up and put boost to this bitch
1.870 60ft [email protected] 225/50 R15 BFG drag radials, full interior.
builtmotorsportswear.com
jdmland.com
jdmland.com
Natural Aspirations
- 55% ricer
Props to a guy going all-motor. ITR pistons a re a great choice on a C1. I would sit down and decide what your long term plans are for the motor and not buy random parts here and there. Stay away from the DC header and the Blox IM. Pick a set of cams and that will help you decide what parts to pick on what RPM level they peak at.
I have never herd anywhere that the Edelbrock header is a SMSP copy and IMO the primaries are much shorter than an SMSP never measured though. The modded Edelbrock has shown 7 WHP on top of an OEM ITR header which gives better power than the JDM DC. EYE would go with a Hytech copy header over both of those and can be bought for ~$350 shipped. I would also look into the Edelbrock Performer X manifold AND Skunk2 Pro1 cams.
I have done A LOT or research on these similar parts and picked the proper ones and got great results.
All-Motor doesn't come cheap but if you cut the corners in the right places it can be manageable. There is NO reason to buy expensive forged pistons and rods, head porting would be nice but a good valve job is crucial. There is a guy in Altoona here that is set up for the valve job you would need I think he charges ~$200.
LMK if you need anything always glad to help. Show these chodes what can be done all motah.
update....
some new parts have arrived...
ITR pistons
ITR rods
ACL race bearings rod/main .thrust washers
honda rings
Blox type-r /gsr flanged intake manifold
buddyclub v-con vtec controller
oem head gasket
ITR valvecover
MSD wires
excedy clutch
more to come.
ITR pistons
ITR rods
honda rings
oem head gasket
ITR valvecover
MSD wires
excedy clutch
more to come.
*moved to correct forum: members rides*
