BB4 (Prelude)
only has like 6 bolts, real easy to take out although i had everything removed so was even easier. besides i also took the interior bolts and replaced all the fender/headlight bolts with the perfect interior ones so engine bay looks lil better without rusted/coroded bolts nowT0DA wrote: So does the rear seat support bracket (that goes all the way across the back seats part of the car) can be taken out without problems?
93 Prelude Si H23 VTEC
haha, glad i dont have your guys problem
Either way head work is almost done. got some valve grinding compound and lapper tool to take care of the 'imperfections' in the valve passages to make sure i got a good seal, other than that should be ready to put this on when i get parts in. Time to order parts and start tearing down the H23
So anyone that seen my other thread in the honda section knows i was doing a VTEC Head on my prelude. Either way IT's DONE!!! Might be able to post some start up vids later but unfortunately i dont have the P28 ecu i sent out to get socketed so got it started and did a small drive down the road but after it gets tuned next week it will be ready for some seat time;)
Here's a couple pics, not the best but will get some better shots up this summer when its out of the garage and i get some stuf touched up
awesome man
1.870 60ft [email protected] 225/50 R15 BFG drag radials, full interior.
builtmotorsportswear.com
jdmland.com
jdmland.com
