99-00 civic Fogs, black bezel, yellow lights, comes with bulbs and brackets also. DOES NOT COME WITH HARNESS OR SWITCH... 30$
2.5" HELLA short ram intake with extended filter, has fitting for IAT sensor and breather - 10$
D16Y8 pistons, rods and rings - used. One piston/rod does not come with rod cap...but the other 3 do. GREAT condish, no scoring or anything. - 40$
D16Y8 Crankshaft - great condish, I mic'd every journal and they're all in spec - 40$
D16Y8 flywheel - Great condish, nothing wrong. no teeth missing or worn - down.
20$
Or buy in a package with pistons/rods/caps/crank and flywheel for 80$.
D16Y8 A/C compressor - used, works, good condish - 40$
D16Y8 block - Honed and painted purple (hehe) great condish, you can repaint if you want...not that hard. No rust on cylinder walls, no cracks, no nothing! - 100$
OEM Si (99-00) wing (high top). VSM in color, nothing wrong with this thing. I might have someone interested..but thought id post this shit up here! very few scratches..from rocks and such. LED is in working condish. - 100$Pics on the car:
Prices dont include shipping. If your interested in something, give me your ZIP and ill calculate shipping costs
Always serviced, nothing wrong, was never taken apart. 100k miles on the motor.
OEM steering wheel and airbag from my '00 Honda Civic HX. Airbag is intact, in proper working order. Was taken off and replaced by a aftermarket wheel and hub. no use for this anymore
Will include backing plate for 5$ extra.
