Th400 + 80mm borg warner (s380) lexus sc300 project
z32power
Post by z32power » April 25, 2008
Here is the car 2 years ago when i bought it. It wasn't the best setup in the world.
Image Image Image Image It was a GT42-71mm with a T6 flange, with half the exhaust housing blocked off :nuts:
I tried to make it work, and ran the car around a little as it was, but it was extremely laggy and didnt seem to make much power.
I will keep posting progress, as i have made a lot over the past year.
'93 SC300 (BW S380 / TH400 / AEM / built motor) http://www.2JZpower.com
'93 300zx Outlaw Class drag car (RB26, Liberty 5-spd, etc etc etc) http://www.Z32power.com
z32power
Here is what i did, we will call it round #2 of modifications. This was still on the less-than-ideal GT42 setup.
(will get some newer ones now that its 100% back together)
I have replaced this turbo in this pic with a GT42-74mm (still on same turbine housing which sucks, i would change it but its gonna take extensive manifold work.)
good shots of the piping i made Image Image the fuel setup i built Image Image the th400 setup (dont think there are any other lexus sc300's running the GM bellhousing setup, i know a lot are running the SP setup) Image Image
z32power
These pics are from last summer
I ran it around for a little while, but it wasn't making the power i wanted...
Image still looks somewhat sleeper, too bad the fuel pump is so GD loud :) and the big ass fart can :unsure:
Image the rear rims have had a turn on just about every car
Image lex is finally making more than 10psi.
i turned up the wick to 17psi and did some testing on the street... shit feels really good.
I'm running at the flashlight drags tomorrow on pump gas/17psi or so. then friday at the import event im gonna run around 28psi and some race gas...
check out my super cold air intake Image haha, was checking for boost leaks
a little transbrake +10psi launch test Image video of idle
http://2jzpower.com/pictures/Joel_Grann ... I_0464.avi
z32power
The motor detonated at a local 1/8th mile drag event, and i decided to build the motor
as of now, i am waiting on the built GE head Image working on the turbo setup as i write this...
borg warner 380 - t4 1.25 A/R 80mm Image
z32power
some updates:
1. got the th400 trans back in, removed the stock bellhousing and replaced it with ultrabell http://www.2jzpower.com/forums/showthread.php?t=905
2. tack welded the adapter to the header, turned out really nice.
next i need to modify the xspower 4" exhaust, modify the gate flange on the header, build a dump tube for the gate.
here is the xspower 4" downpipe. Really nice stuff for under $400 Image here is the adapter flange i had made. it is 3/4" thick, then it was milled on a angle from 3/16" to nothing to lean the turbo in towards the header. this was then welded onto the stock t4 flange on the xspower header. the exhaust manifold i am also going to brace heavily... Image here is the huge xspower intercooler. I cut the front bumper today to give it more flow Image sat the downpipe in there for test fitment... will need a different vband flange and may need to do some cutting to make it fit better with my setup. it's close though! much better than starting from scratch! Image turbo installed. very small clearance with runner #1. for now, i ground off the casting bump 1/2 way around the compressor housing. Image Image Image Image
z32power
building the piping... this will never blow off :biggrin:
had to cut the compressor off and put a 90 degree... gotta love vibrant performance products... i probably just spent $500 in fabrication components Image 3" vibrant v-band in aluminum Image its all tacked and ready to go to the tig welder Image spot on Image Image time to take it to the welder Image
z32power
finished the downpipe and midpipe. will finish rest of exhaust this weekend...
very close clearance between runner 6... had to do some pretty exhaust cutting... Image the midpipe vband Image Image the modified manifold Image Image Image last cut was a real biatch Image Image off the car Image its getting closer, still have the wiring mess to figure out, the C.O.P setup to figure out, and still waiting on the built NA head to come back.
z32power
some of these threads are old, from last year, i just copied and pasted them from another forum...
the intercooler piping, exhaust and new turbo setup are things i have been completing over the last 3 weeks or so...
the car should be done in about 3 weeks
Joel
mcmBuilt
Post by mcmBuilt » April 26, 2008
Nice Project!!!
Post by munster » April 26, 2008
Awesome, Joel. Can't wait to see this out and about. :bang:
