Idle Problems
popeye
45% ricer
Idle Problems
Post by popeye » January 26, 2004
I have a b20b in my crx and it idles around 2 grand. I dont know what it is from i have tried the idle screw and checked the throttle cable. I have a b18a intake manifold and there are two lines that go to the stock air box but i have a intake and have those lines capped could that be it
Re: Idle Problems
Post by Nikku » January 26, 2004
b20rex wrote:I have a b20b in my crx and it idles around 2 grand. I dont know what it is from i have tried the idle screw and checked the throttle cable. I have a b18a intake manifold and there are two lines that go to the stock air box but i have a intake and have those lines capped could that be it
have you bothered to check for vacume leaks? also you might want to make sure that all of the old IM gasket was cleared off of the head when you changed IM's
phan
40% JDM
Re: Idle Problems
Post by phan » January 26, 2004
temp wrote:have you bothered to check for vacume leaks? also you might want to make sure that all of the old IM gasket was cleared off of the head when you changed IM's
yup, a vacuum leak sounds about right. who did the swap and/or how long has it been in the car?
popeye
45% ricer
I did the swap it has been in for about 4 months but when i got it in that day i drove it to get painted and then got it back and it sits in my garage cause i lost my license for 90 days and it winter
phan
40% JDM
so have you always had this problem? was this your first swap?
miyagi
Post by miyagi » January 26, 2004
no it wasn't his first - swapped a b18a into his car first, but blew a headgasket or something so he dropped the b20 in. He also dropped a zc into another of our friend's crx. The same people helped with all 3 swaps.
i told him to just replace all the tubes for the vacuum lines, and see if that fixes it. And if not, then look for something else
spnfedeg6
65% ricer
idle probs
Post by spnfedeg6 » November 29, 2004
take some carb cleaner and spray it around your intake manifold and throttle body, if the idle changes you have definite vacuum leak. Most probable is either throttle body gasket or intake manifold gasket.
C.R.X
Post by C.R.X » December 01, 2004
i had the problem few months back. In my case it was because the throtle cable was too tight. I suggest you check the following things as basic checkups:
1. throtle body valve closes all th way
2. spray degreaser on vacuum line and let motor run then look for bubbles, if any, then they are leaks.
3. Does your car idle okay at first then high after a while? if so, it can be fitv and eacv issues.
4. double check you manifold swap, espeacially neglected vacuum lines or plugs.
I help this helps. good luck.
