2-7offsuit
- 90% ricer
Post
by 2-7offsuit » September 30, 2004
There's a lot of white smoke coming out of the exhaust. It seems to be mainly when I shift. Also If I stay in vtec very long the CE light comes on. It says 1, which is the o2 sensor, and 22 which I think is the vtec pressure sensor. The car is a 92vx with a B16b and p30 ecu. I had to rewire the goofy vx plug for the normal 4 wire o2. Could my o2 sensor just be bad? Would this cause excessive smoking?
What would cause the vtec code? I already cleaned out the screen and it has plenty of oil.
thanks
Post
by tenchu » October 01, 2004
BHG?
Post
by BRYCE » October 01, 2004
Blown Head Gasket
Post
^what he said
Thanks Blastage
2-7offsuit
- 90% ricer
Post
by 2-7offsuit » October 04, 2004
I hope that's not the problem. How can I check that ? a compression test?
Post
by tenchu » October 04, 2004
Yeah that should work, or change your oil and see if it looks fucked up, i forgot how it would look, i think like there would be white splooge lookin shit in it. I hope its not that too mang, there a bitch
2-7offsuit
- 90% ricer
Post
Could the car just be running too rich or lean due to a bad o2 sensor? It pretty much just does it when I shift. It seems like if it was the head gasket it would be smoking all of the time. Also, wouldn't the coolent level be low if it was the head gasket. Because that seems fine.
Post
:-/ maybe? I dont know too much about it
Post
by munster » October 04, 2004
Rings?
Do a compression test.
