Digital Camera Question
photo shoots & ps chat. show off photography car related or not.
JaySmith
30% JDM
Post by JaySmith » February 18, 2005
Just out of curiousity when purchasing a replacement, or additional battery for your digital camera, does the amount of mAh matter? IE: My current battery is 570mAh, however you can get replacements that are almost 1000mAh.
Lastly, do we have a photography section? If not, maybe that should be something taken into consideration. ;)
Post by tenchu » February 18, 2005
As far as the battery question goes I have no idea.
As far as the photgraphy section, we didn't have one, but we do now. *flexes admin muscles* http://www.thejdm.com/forums/viewforum. ... e03352f473
Post by Sean @ NDF » February 18, 2005
good idea for the photography section. :up:
JaySmith
30% JDM
I guess this topic should be moved into the new section huh? ;)
Post by tenchu » February 19, 2005
:up:
JaySmith
30% JDM
Post by JaySmith » February 21, 2005
No one? :P
AcuracyRR
Post by AcuracyRR » May 22, 2005
mAh stands for milliamp-hour. What that means is that it is a form of measure to distinguish the strength of a battery. They say that the higher the mAh rating, the longer the battery will last, which is true in a generalized way. Some argue that if you get a higher mAh rating than within say 100mAh of your factory battery that it may cause problems. I personalize don't believe that, but rather believe it depends upon the materials from/manner in which the battery is made. So if you pick up a name brand battery you should be fine if it is 1000mAh. Hope this helps.
