Colour (Mugen Valve Cover)
Just wondering if anyone knows of a high temp engine paint that's similar in colour to the one on the Mugen Valve Cover? I've tried VHT, but the only offer a flat Gray.
- Sean @ NDF
Hmm Cast Iron Gray eh? That actually looks pretty close. Who makes it, do you remember off hand? Did you do a high temp primer too? Or just straight paint?
I tried using that VHT Wrinkle Paint. Christ is that shit a challenge. Definatly not a paint for the perfectionist. haha So now I was wanting to go with something a little different, lighter in colour.
i bead-blasted it first. no more bumpy black paint, no primer, just painted then sanded the lettering , bu tbe careful on a dx anyway the H is real close to the cover. i taped it all off so no t to scratch the paint i just sprayed so nicely. no clear coat either. sorry i dont remember the brand, got it at Advanced Auto.. same brand that has the colored caps for hot engine paint and one is "ford Gray" but that looked ot light so i got this (same brand).
I used VHTs Wrinkle Paint. Followed the instructions to a T. And the wrinkle was very inconsistant, infact some areas didn't even wrinkle.
Ford Gray. I know what brand your talking about now.
I was looking at that Gray yesturday. haha By the way, an easier way is to use vasiline. You use a Q Tip, and apply it to the lettering. And once the paint has dried, you can peel those areas off with your finger nails.
ill post more when it is on the motor again...
