Brake light
spdyslvrEX
Brake light
Post by spdyslvrEX » June 29, 2005
Alright so I did my brakes the other day and my dash brake light stays on.
You know the one that comes on when you have your E-brake on?
What should I do?
Time to change my signature....
Post by tenchu » June 29, 2005
Check your brake fluid. Also check that the the fuses are fine?
TRAVASS
10% JDM
Post by TRAVASS » June 29, 2005
I was gonna say check the fluid, but if thats not it check the switch at the actual handle.
Post by .saint » June 29, 2005
mine stays on once in awhile. you might need to pop your console out and take a look at the harness. mine had a lil short in the wires i had to tape up. from pulling the ebrake tome after time it wore through the wires.
Post by BRYCE » June 30, 2005
its the ebrake harness.
spdyslvrEX
Post by spdyslvrEX » July 03, 2005
Where is the Ebrake Harness? under the center console? 2001 EX.
