Does powdercoating wear off with paint thinner?
idreamidrive
Post by idreamidrive » September 03, 2005
AcuracyRR wrote:If you want to remove powdercoating try using airplane paint stripper. Its what I used to remove the stock valve cover coating and it made the stuff fall off like a banana peel. I'm not sure how effective it would be on powdercoating, but it would be your best bet. HTH.
Mike
paint thinner won't work on powder coating... only tihng that works is sand blast like somebody already said, but the thing is. if the powdercoating was done well sand blasting won't take it all off. powder coating is a serious business ppl. you are pretty much stuck with it for LIFE
Signature
AcuracyRR
Post by AcuracyRR » September 06, 2005
wasnt sure if the airplane thinner would work better. I know that the factory valve cover coating wont come off with paint thinner but comes off with the airplane thinner....might be worth a try on powder coating....have to remember that airplane paint sees rediculous speeds, temps, and conditions....
good luck.
mike
Post by Sean @ NDF » September 06, 2005
yea, i decided to keep the pd vc. But I want to pd my stock one
Secret Squirrel
Post by Secret Squirrel » September 06, 2005
banzai...lemme see what i can find out...i will let u kno when i talk to the manager tommarow
Secret squirrel wrote:banzai...lemme see what i can find out...i will let u kno when i talk to the manager tommarow
gracias senior
latenightcustom
Post by latenightcustom » September 10, 2005
if you want to remove paint or a powder coat find some aircraft paint remover. the stuff is awsome
