thermostat help
Secret Squirrel
thermostat help
Post by Secret Squirrel » October 30, 2005
ok, i have a buddy who has the option to buy a 180 degree F thermostat or a 192 degree thermostat. I want to kno which one is better. I say the hotter one, he says the colder one.
my arguement:
a hotter thermostat will make the engine run hotter which will have less heat transfer from the explosion in the cylinder. there fore since less energy is being turned into heat more of the energy from the explosion will be turned into work creating more power. and i understand it wont be anything noticable and there is prolly risks of running the motor hoter wich out weigh the benifites.
any suggestions? does my post make sense?
Post by Nikku » October 30, 2005
the cooler one, i follow your logic but it is flawed. here is why the cooler one is better, the thermostat will open sooner, thus turning on the fan sooner, thus keeping the motor at a cooler overall temperature
Hercules
50% ricer
Post by Hercules » October 30, 2005
i'd go with the colder one also, i dont have a good reason except my car was running pretty hot with the stock radiator and seemed a bit laggy, so i put an integra gsr radiator in it and it felt alot better/cooler. i think cooler is better.
1996 VSM Civic Dx Hatch - Sold
1990 Crx Si - Sold
1994 Accord ex DD
Dc2gsr95 wrote:i'd go with the colder one also, i dont have a good reason except my car was running pretty hot with the stock radiator and seemed a bit laggy, so i put an integra gsr radiator in it and it felt alot better/cooler. i think cooler is better.
to a degree cooler is better, too cool and the engine will not perform properly
Secret Squirrel
yea...but in theory im correct?
cuz all the engine is is an air pump. so if more of the chemical reaciton is turned into work and less into heat there would be more power, so runing hotter temps means less heat loss, which means more chemcical energy bing turned into usable work
idreamidrive
Post by idreamidrive » October 30, 2005
wow... a tardtastical question. you do know that once your thermostat opens up it stays open for the most part. so its just initial temp that it starts doing its work.
Signature
Secret Squirrel
yes but if ur thermo opens at 180, ur core temp is gunna stay right around there...but if it opens at 192 then core temp is gunna be higher
idreamidrive
not neccassarly
Secret Squirrel
defend ur answer fool!
SAS
tommybanzai
25% ricer
Post by tommybanzai » October 31, 2005
why don't you just buy the hotter one if you think your philosophy is right....??...and put an end to this nonsense
the new and slightly improved...don't piss me off, and i won't f#*k with you!!! *gggrrrr*
