no... i wanted to do a f20c in a datsun 510... then i found, just one, that was already done. so i was still thinking of doing it and making it betterToByTuNeD wrote:idreamidrive wanted to do that too....banzai wrote:I know a miata with a f20c has been done =)
i just had the stupidest idea...
- idreamidrive
- ls.pwrd.hb.
- 75% JDM
- idreamidrive
- ls.pwrd.hb.
- 75% JDM
munster wrote:Anything's possible with money. That would actually make more sense and be more bulletproof than a Bseries w/ CRV rearend since the CRV axles are junk.
Simplified:
I imagine once you got the rearend fitted up it would just be a matter of getting the motor in. Then make up the difference in length in the driveshaft. I haven't seen the setup on a S2K rearend, though.
Uhhhh... and creating a driveshaft tunnel which is THE biggest issue/headache/fabrication of the whole swap.
