wireing vtec in a 97 dx hatch
vtjdmsir
85% ricer
Post by vtjdmsir » May 27, 2006
I have a b16a1 and i have the wireing harness ecu from the b16 and my cars stock wiring harness. Im getting a od1 to obd2 harness just wondering what is the easest way to wire vtec and the best way of doing it
Thanks James
James Goodyear
thejdm.com / 802 Squad
Post by munster » May 27, 2006
Get your pinout for the obd1 ecu and run the necessary wires from the bay into the harness and pin them where they need to be.
http://www.ff-squad.com/tech/wiring/wiring.96-98.jpg
http://www.ff-squad.com/tech/wiring/wiring.92-95.jpg
vtjdmsir
85% ricer
Post by vtjdmsir » May 28, 2006
do i use the b16 harness or my stock harness
Post by munster » May 28, 2006
Use your stock harness and add the vtec wiring.
Obd1 harnesses are on both sides of the bay. obd2 has one cluster of plugs.
Is it an obd1 motor too?
vtjdmsir
85% ricer
yeah its a b16a1 obd1
Ok.
Use your stock harness. You're going to have to splice the injector wires and switch some wires. You'll also have to lengthen alot of wires. There's alot of plugs that you have to splice because the obd1 has round plugs on some sensors. You're also going to have use obd2 distributor guts so the plugs match unless you feel like splicing everything. Then you can plug in the jumper harness and run the obd1 distributor.
Good luck. It was a long time since I did mine, but just take your time.
vtjdmsir
85% ricer
Post by vtjdmsir » May 29, 2006
i got a brand new dizzy with the motor so to use the obd1 dizzy i whould have to use my obd1 ecu with the jumper harness
Post by munster » May 29, 2006
To use the obd1 distributor guts you have to cut the dizzy plug off of the obd2 harness and splice into the obd1 plug.
The main reason you have to cut and splice are different plugs and the wiring harness being too short.
