Idle Problems
spdyslvrEX
Re: Idle Problems
Post by spdyslvrEX » January 31, 2010
Matt, Are you thinking bad fuel pump? or are you just saying there is to much fuel? Help me out here Homie....
Apparently Walbro is the only fuel pump for my car...and you have to add on a return fuel system for the 7th gens....Those are about $630 (which I don't have....)
This car is on the edge of getting put back to stock and being sold....or maybe that guy will still trade me....I just wont tell him what all he has to do....Ha ha ha ha
Re: Idle Problems
Post by kotomile » February 01, 2010
I'm saying if your plugs are black and smell of fuel, I would not think the fuel pump was the problem. Just about everything is pointing to ignition here.
tenchu wrote: Every 3 oil changes on the cheap NGKs?? Was your car tuned by God?
Missed this earlier, sorry.
Tuned by Jerry at DIYautotune. I guess if anyone knows how to tune Megasquirt, it has to be him..
Re: Idle Problems
Post by tenchu » February 01, 2010
Hahaha I guess. I'm still trying to find a competent tuner for a frankenstien phase1/phase2 subie with Hydra on E85 w/ water injection
spdyslvrEX
Re: Idle Problems
Post by spdyslvrEX » February 06, 2010
Matt, How does this point to ignition? Today I went by Autozone and ran another code reading. There were no Misfire codes this time so I believe that the changing of spark plugs fixed that....What else could it be?
been doing some research and found a forum where one guy said it could be the O2 sensor....since I am throwing that code I will try to fix that....
Re: Idle Problems
Post by tenchu » February 06, 2010
spdyslvrEX wrote:been doing some research and found a forum where one guy said it could be the O2 sensor....since I am throwing that code I will try to fix that....
You mean I tried to tell you to fix?? Hahaha
spdyslvrEX
Re: Idle Problems
STFU!!
Ok so the O2 sensor is only about $60 but I am still going to try using the one I have...I just have to switch some wires around and if that doesn't work then I guess I will have to buy a new one....Come on Tax returns....
Re: Idle Problems
Such harsh words towards someone whos tried to be so patient with a car thats so stubborn. Not nice man!! Haha
spdyslvrEX
Re: Idle Problems
Post by spdyslvrEX » February 08, 2010
Matt? Ignition? How is this the problem? I mean I am still not getting any misfire codes. Also, I tried to see what would happen if I was at a low speed 35-40 mph and put the car in Cruise Control....at 35-40 mph and 2500ish RPM the car bucks....(as if fuel is shutting on and off rapidly) I know that I am not getting and codes for it but could this be a TPS problem? I still haven't had time to change the wires around for that O2 sensor, but I just don't see how that is causing the idle problem....Unless the O2 sensor tells the ECU how much fuel is actually being used. And if these wires being mixed up can't tell the ECU the correct readings, then....the ECU can't tell the IACV what is supposed to be going on and then the IACV can't tell the TPS what's supposed to be happening....am I going down the right path here or am I way off?
tenchu wrote:Such harsh words towards someone whos tried to be so patient with a car thats so stubborn. Not nice man!! Haha
Josh....yea, whatever....lol
spdyslvrEX
Re: Idle Problems
Post by spdyslvrEX » February 09, 2010
http://www.ehow.com/facts_4899182_what- ... ensor.html
Check this out....read the whole thing....
Re: Idle Problems
Post by kotomile » February 09, 2010
Give the O2 sensor a try man, looks like the plugs may have gotten rid of some misfire but not the root problem. Trial and error man, sometimes that's what it takes...
