Chinga's new DA9 thread.
DA 9_Chinga
Post by DA 9_Chinga » September 06, 2010
So here is a list of shit done already to the teggy. I will be updating this every time i do something new to her. She runs strong nothing better than pulling 8000k shifts screamin in VTEC. Mostly will be doing body work on her since the interior is so clean and the motor is already swapped.
*b16 from a jdm civic sir. has little under 30k. did a compression test today and got 215-217 accross the bored. had a vlave adjustment. cylinder head is fresh and is stilll silver in the inside. oem honda gaskets and harware.
*J1 b16 tranny with lsd from a 91 civic sir. has about 50k on it.
*compition stage 1 clutch with 574 miles on it. very smooth and grabs nice.
*brand new oem honda clutch cable
*koni yellow shocks for a 94-01 integra
*GC custom spring rates from eibach. 440 in the front and 500 in the rear
*GC extended top hats front and rear.
*power slot rotors in the front with hawk hps pads
*brand new axles
*innovation mounts
*fluidyne half radiator with oem honda radiator hoses
*harness and fuse box fully tucked(didnt cut ANY wires)
*abs delete but still use the abs MS and booster
*phearable.net ecu with 2 step set at 4200 and vtec at 5200
*megan header wraped
*hks hi power exhaust
interior and exterior
*ls's seats with ZERO rips or stains.
*AC was deleted
*using a cluster from a 91
*fidanza short shifter with urethane bushings for the linkage and new oem honda shift pin and hardware.
*itr shift boot
*94-01 gsr shift knob
*battery relocated in the rear.(optima red top)
*using a 90-91 bumper with lip. i think they look better then 92's
*MINTY jdm headlights with yellow fogs with the fog light trick done
*hood lifted in the rear.
*crx si wheels painted green. they are only temp
*all the cluster and cllimate bulbs changed to amber.
Here are pics i took this weekend after a wash and wax Image Image Image Image Image Image Image Image Image Image Image Image Image -Adam
Re: Chinga's new DA9 thread.
Post by .saint » September 06, 2010
fresh :thumbup:
Post by munster » September 06, 2010
I don't think there's enough DAs :up:
DA 9_Chinga
thanks saint. so happy to be back here and the chances of having another da9 is crazy. cant believe i came back totaled my legend and then scooped up a DA...lol
DA 9_Chinga
thanks munster! lol well they overrun my town but i was the first to rock one in my town back in 2003 lol but i will be rocking the cleanest one cause everyone else here is hacks and cheap...
There's a ton of DCs around here, but you rarely see a decent DA. I saw a dark green DC today w/ yellow high beam lenses and a supersonic blue DC w/ a jdm front for example.
So props for keeping that gen alive.
Jams_ek
Post by Jams_ek » September 07, 2010
nice adam glad too see you got a nice DA again
DA 9_Chinga
Post by DA 9_Chinga » September 07, 2010
munster wrote:There's a ton of DCs around here, but you rarely see a decent DA. I saw a dark green DC today w/ yellow high beam lenses and a supersonic blue DC w/ a jdm front for example.
Guess it all depends on the area i've only seen like two jdm front's on 94+ integra's around here so that's what i was aiming for or a ek9 but they are still pretty pricey so i am happy i settled on this cause when i sat in it i felt 17 again and already been pulled over. first time in like 3 years (for speeding at least lol)
Jams_ek wrote:nice adam glad too see you got a nice DA again
Appreciate it jams, glad to be sitting on the floor in style again lol
DA 9_Chinga
Post by DA 9_Chinga » September 09, 2010
i need some suggestions on a paint color.. im leaning towards something lighter maybe an off white or tan or maybe a gray..
Post by munster » September 09, 2010
Repaint it black. :x
of the three choices...white.
