h23 vtec do you thinks good enuff to run a bit of boost
boost. na tuning. bolt ons.
kaoticimports
Post by kaoticimports » April 15, 2005
-93 prelude vtec head w/ 0 miles
new valves, springs, retainers, seals, etc
fully ported n polished(stage III, cost $550)
3 angle valve job
miled head(forgot how much they took off) raised compression
comes w/ all sensors and intake manifold, new honda head gasket, new timing belt, new intake/exhaust gaskets, etc.. STR cam gear(silver)
-94 h23 block w/ 0 miles
arias piston (8:5:1)
new rings etc
decked and bored over .015 (compression up to 9-10)
crower rods
sleeved 1/8 inch
new h22 head studs, lightweight crank pulley
stage 5 clutch/pressure plate (full race clutchmaster)
rear and tranny side hcp mount kit for dc2/eg
-brand new stage 3 axles (400hp) made for the h22 intermediate shaft instead of the accord one
think its good to run boost let me know wat you think
the 3 most feared words: POWERED BY HONDA
HONDA: Hold On Not Done Accelerating
Hondas are like that old girlfriend thats just always around in case you need some action but you dont stay with her because you think you can do better. but in time you realize she was the best thing you ever had
Re: h23 vtec do you thinks good enuff to run a bit of boost
Post by tenchu » April 16, 2005
kaoticimports wrote:-93 prelude vtec head w/ 0 miles
3 angle valve job
new rings etc
crower rods
sleeved 1/8 inch
Raised compression + Boost = Bad. You wont be able to run too much boost w/o building it.
Post by kotomile » April 16, 2005
This is to go in the 'bagged show Civic?
Here's my equations for this idea:
H23 + VTEC head = great NA power
H23 + VTEC + mild build + raised Cr = Sweet
H23 + VTEC + mild build + raised Cr + boost = pointless.
H23 + VTEC + mild build + raised Cr + boost + show car = Why?
Post by munster » April 16, 2005
My opinion:
:down:
I would stick to what you have. If you are dead set on turboing an H block why not just build the H22 and save yourself time and money?
:stupid:
kaoticimports
Post by kaoticimports » April 16, 2005
i was just seeing wat yall thought
