EK to EG??
2.SloEK
70% ricer
EK to EG??
Post by 2.SloEK » October 13, 2006
Wiiill EK Coupe suspension fit on a EG hatch????
PLEASE PLEASE PLEASE SAY YES!!!!
idreamidrive
Post by idreamidrive » October 14, 2006
Yes!!!... actually i have no idea
Signature
Post by Sean @ NDF » October 14, 2006
no
spock_rocker
Post by spock_rocker » October 16, 2006
the front strut forks i believe are different and i know for a fact the rear LCAs are different. now the DC and EG chassis are the same!
AIM = Hangoroshi Omoi
http://www.MemoryFab.com PM me if you need anything
B20 powered Gu'ripu Kaijuu!!
...TeamSloth:htolSmeaT...
phunhaus
Post by phunhaus » October 16, 2006
The front shock forks are identical as are the mounting holes. The fronts are never a problem. In order to get the rear to fit you need to change out the lower shock mount bushing - the center one in the contrrol arm.
The EG runs a longer bushing so you'll have to press it out and run the shorter EK bushing. That is the only difference.
Hercules
Post by Hercules » December 20, 2006
phunhaus wrote:The front shock forks are identical as are the mounting holes. The fronts are never a problem. In order to get the rear to fit you need to change out the lower shock mount bushing - the center one in the contrrol arm.
correct..i'm running eg/dc2 struts on my ek. Fronts fit perfect, Rears i used washers in between the fork and the bushing due to the thinner bushing/wider fork.
SingleCamEJ8
Post by SingleCamEJ8 » December 20, 2006
this guy is very knowledgble...and provides great information :up:
BUILT MOTORSPORTSWEAR
"the USDM kid"
vtecdood
Post by vtecdood » December 20, 2006
ebrake cables are different too
nizzan1984
Post by nizzan1984 » May 26, 2007
srry for the randomness. but i didnt know u were on here?!?!:o
"God invented turbo lag to give the domestic guys a false sense of security."
jdmcivic98 wrote:Jewish Domestic Market
*CACKYWHEELS
Approved Vendor
Post by *CACKYWHEELS » May 27, 2007
spock_rocker wrote:the front strut forks i believe are different and i know for a fact the rear LCAs are different. now the DC and EG chassis are the same!
This guy's obviously never put an EK suspension setup onto an EG, so don't listen to him
The other guy is correct the fronts mount up exactly the same, and the rears require a 3MM washer or so since the bushing on the EG LCA is a little thinner than the EK LCA.
