Axel Nut Wont come off!! Turned to cant get hub off axel!!
Post by .saint » October 05, 2004
good luck.
robry
70% JDM
Post by robry » October 05, 2004
we just took my friends axle nut off his dodge 1500 pickup. He had a 10 ft breaker bar on it and it wouldnt budge. Just heat it with a torch, we used a propane torch and that worked. Just heat it up a bit and it should come off.
06' RSX-S Turbo | PTE SC6162S 417whp!
phan
40% JDM
Post by phan » October 05, 2004
power tools own you! my impact gun makes quick jobs of axle changes...woohoo! :P
Post by BRYCE » October 05, 2004
alright good and bad news got that bitch off with some pb and a longer breaker. But i cant get the axel from the hub. i think i need a hub puller?? fuck i dont even now what i need.. blah enough for today i am going back out and putting it back together i got a hot date tonight!! **WINK WINK**
phan
40% JDM
gotta pull the lower ball joint out from the LCA first...this can be a bitch as well. once you do get it off, tho, you can push the axle out easily. :)
Nope... hah i got the ball joint out of the LCA (pretty loose had to for bushing not even a month ago) so ya i dont know why its so tough??
phan
40% JDM
ok, take a thin hammer or something and tap the axle out of the hub.
we need ban to start posting here again. he has a trick to getting the balljoint apart real quick.
ban
Post by ban » October 05, 2004
i'd like to give away my trick but i'm to stupid to explain it....sounds like u had no problem with it though... lie phan says all u need to do is tap the center of the axle shaft and it should slide out of the splines. if its rusted and doesn't wanna slide out squirt it with pb.. and get a bigger hammer...good luck
So the threaded shaft that the axel nut was on, thats what i pound out?? Fuck i am soo close
