fourth generation civic & crx tech. [84-91]
Moderator: Nikku
mr.green
- 80% ricer
Post
by mr.green » August 18, 2005
What do you guys think I should put into my chassis once its finished at the shop?
1) A built LSVTEC with boost
2)A K20 with TODA internals N/A
Both will be near the same price doing the preliminary math. So lets hear everyones opinions.
My car is cleaner than your ass.
Post
by Sean @ NDF » August 18, 2005
a built ls/vtec with boost will be no where near as expensive as a k20...and you would go with the boosted b series if your smart.
Post
by tenchu » August 18, 2005
Depends what your going to use it for. Boosted B on a road track = teh sucks. But on the strip, teh win!
Post
by munster » August 18, 2005
Boosted B.
Post
boosted b on the track wouldnt be the suck...depends on what turbo actually.
My setup would be damn good for road racing, because it spool rather quickly, and I would be staying in the 4-5grand range anyway so I would always be ready to boost...
Post
by munster » August 19, 2005
Both setups would run strong. I would just go turbo because you'll be able to set higher goals safely. Are you planning on bore and sleeve too?
mr.green
- 80% ricer
Post
by mr.green » August 20, 2005
yes, FULLY built. The costs would be VERY close for all I would want to put into the B block. vs. the cost of a nearly stock K engine with the head upgrade and ECU.
ls.pwrd.hb.
- 75% JDM
Post
by ls.pwrd.hb. » August 20, 2005
well a fully built ls on boost is going to generat more power than an all motor k depending on how far you push it
low n slow
Post
by munster » August 21, 2005
84mm ls/vtec + GT series turbo = Fun.
Post
by BRYCE » August 21, 2005
K20! NA All the way! will be the best all around.
